Discrete Opamp Open Design - Page 11 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 23rd August 2012, 07:34 PM   #101
scott wurcer's Avatar
Originally Posted by RNMarsh View Post
Scott - you have the floor/ball..... take it and run. Are you going to do a discrete version of the 627 with us? Or? -RNM
I have something simple to start with as my discrete 627 is complicated, but I need to do it from home tonight.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 23rd August 2012, 07:38 PM   #102
dirkwright's Avatar
Originally Posted by bcarso View Post
Since virtually all of the likely designs to pour forth are going to want an output buffer, I dredged up and dusted off the attached.
It can be scaled back to lower rails without too much trouble. The bandwidth per se from a 1k source R is about 35MHz. There is the advantage of reduced thermal distortion when used with about a 515 ohm load, since the output devices are equidissipational*, that is, their dissipations roughly track. But when, as we anticipate, this is inside of an overall global loop with plenty of loop gain, the rest of the works will easily correct for dissipation-induced shifts, as the shifts should be fairly slow, and thus the thermal concerns should be minor.
The bootstrapping of the input devices raises the input Z, but also requires some lumped C to reduce peaking. Since such C is constant, the distortion at high frequencies at the input is reduced.
Short-circuit protection is left as the proverbial exercise to the reader.
Brad
*the approximate condition for this is that the peak output current into the load at just before onset of clipping is twice the quiescent current. Things are slightly more complicated by the emitter ballasting and the fact that the input devices draw their operating current from the output devices due to the bootstrap arrangement.
What I thought was meant by "opamp" was that it had both + and - inputs that were balanced to ground and basically required a differential input stage. There's absolutely nothing wrong with this circuit, but I assumed we were limited to a certain kind of topology. Did I make a wrong assumption?
Old 23rd August 2012, 07:42 PM   #103
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
It is limited by beta of output transistors and currents supplied by sources.
The Devil is not so terrible as his math model is!
Old 23rd August 2012, 07:44 PM   #104
Wavebourn's Avatar
This circuit is an output buffer that Brad proposed.
I have another version, can't find the picture...
Old 23rd August 2012, 08:03 PM   #105
dirkwright's Avatar
Oh, my mistake. Sorry Brad!
Old 23rd August 2012, 08:05 PM   #106
dirkwright's Avatar
If we are not counting current sources, what about current mirrors? Do we not count them also?
Old 23rd August 2012, 08:24 PM   #107
john curl's Avatar
You should quit 'counting' and start designing. These arbitrary rules are self limiting.
"Condemnation without Examination is Prejudice"
Old 23rd August 2012, 08:25 PM   #108
bcarso is offline bcarso  United States
diyAudio Member RIP
This is presented as a PART of a final opamp design. Note the triangles in the various Groner-presented topologies? Those are where this would go --- they are ~unity-gain buffers.
EDIT: sorry read and replied before I saw Wave's reply.
Old 23rd August 2012, 08:25 PM   #109
expert in tautology
bear's Avatar
In terms of buffers I like Chris Paul's buffer design... not sure where to find the schematic though... a similar on was suggested in a diy thread a year or two ago and I piped in with the requisite moving of the input devices to bootstrap them to the outputs... maybe I can find that if I search enough...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 23rd August 2012, 08:28 PM   #110
diyAudio Member RIP
It might survive a momentary short, like a brush with a clumsy test lead ground, but it's not likely bulletproof for magic smoke releasing probers
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright 1999-2017 diyAudio
