Discrete Opamp Open Design
Old 15th September 2012, 11:39 PM   #961
john curl is offline john curl  United States
john curl's Avatar
I prefer minimal series thru-path, BUT not minimum active parts for its own sake. IF you create an arbitrary maximum of active devices, you reduce the field of choice AND the potential optimization of any particular circuit. I think that Einstein said something like:
Everything should be made as simple as possible, but no simpler. '-)
"Condemnation without Examination is Prejudice"
Old 16th September 2012, 12:02 AM   #962
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
OK. So, make opamp as good as possible and as simple as possible. but no simpler.
Now where were we??
Old 16th September 2012, 12:21 AM   #963
ChocoHolic is online now ChocoHolic  Germany
...that's a matter of taste.
To me our OP amp discussion has moved to much to high component count.
I like Gerhard's idea to settle an symmetric version of the LinuxBuffer.
Unfortunately my understanding how to symmetrize the buffer leads to
higher component count than Gerhard's schematic...
Just a thought, but not simulated.
Old 16th September 2012, 12:45 AM   #964
RNMarsh's Avatar
Symmetry IS important.
Last year I was making just a buffer to entertain myself and was up to 12 transistors and heading towards more before I said - 'stop'. Way too many transistors.... but the distortion was unmeasureable (really low). IMO I decided for myself that the lowest harmonic content couldnt be the only goal. What other parameters make for a better audio circuit besides noise, IM and harmonic content? How important is CMR in audio? PSR is important but can be divided between power supply and circuit.
Old 16th September 2012, 02:49 AM   #965
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
With +/- 24 VDC supplies, a final stage of supply decoupling might be included in the package. Maybe even with a professional +24 dbu output? It's a good place to put a final supply decoupler anyhoo.
Thanks,
Chris
Old 16th September 2012, 02:59 AM   #966
john curl's Avatar
I just did it Richard! '-)
Old 16th September 2012, 03:00 AM   #967
john curl's Avatar
Takes more parts, Chris, look at my example.
Old 16th September 2012, 03:21 AM   #968
bcarso is offline bcarso  United States
diyAudio Member RIP
Agree . Minimize the through path, but the supporting cast should be as required. Damn the expense LOL.
Old 16th September 2012, 04:38 AM   #969
RNMarsh's Avatar
[QUOTE=bcarso;3166631]Agree . Minimize the through path, but the supporting cast should be as required. QUOTE]
I agree, too. I count a cascode as one and dont count CCS et al.
John. You just did IT? What does - you just did it mean?
Whats the best power supply topology... series or shunt reg or both?
Old 16th September 2012, 12:02 PM   #970
linuxguru is offline linuxguru  India
Send a message via Yahoo to linuxguru
Just for historical interest, here's one of the very conventional predecessors to the CCB. It's fairly ordinary in distortion, but has high bandwidth. It's probably easier to make a symmetric version of this one...
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 07:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 04:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 01:52 PM
Copyright ©1999-2017 diyAudio
