Discrete Opamp Open Design
Old 23rd August 2012, 03:28 PM   #81
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Originally Posted by bcarso View Post
Number two (from post 68) is not too bad. Whose is it? It looks like something that really works.
What?!?! you didn't see the "Je-990" on that one? I assume you mean this one in the middle?
Old 23rd August 2012, 03:30 PM   #82
bear is offline bear
expert in tautology
bear's Avatar
Two of the first lot?
JE-990!
hee hee.
Or did you mean the second lot as a whole??
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 23rd August 2012, 03:31 PM   #83
dirkwright's Avatar
Originally Posted by scott wurcer View Post
Sorry guys EVUL started this so fast I was caught off guard. I hope to put up a couple of ideas later today. I don't think complexity is a goal in itself, performance is. I also don't think a design contest with an 8 transistor limit should be a prime goal.
OK, so re-write the rules then....
What IS the goal? So far, it's been talking about this transistor vs. this other one and whether or not it's still produced.
I actually don't like the differential opamp topology anyway. I don't use it (when I play around in my spice simulator) except for power amps.
Old 23rd August 2012, 03:40 PM   #84
bcarso is offline bcarso  United States
diyAudio Member RIP
My bad. The one in the middle from post 70, with the dual JFET front end. I like that one.
Old 23rd August 2012, 03:54 PM   #85
dirkwright's Avatar
You'll have to ask ThorstenL about that one.
http://www.diyaudio.com/forums/analo...t-ii-1886.html
All I got so far is that it is very old. (1973?)
I was just posting random schematics to get the creative juices going here. I don't mean to endorse one over another one. I'm not really knowledgeable enough to know which would be better than another anyway.
Old 23rd August 2012, 04:49 PM   #86
diyAudio Member RIP
I hope he can be persuaded to return someday. However, this seems to be the season for leaving sites (I recently left a couple of "social" ones, no doubt pleasing some and disappointing others).
Old 23rd August 2012, 04:53 PM   #87
hhoyt is offline hhoyt  United States
hhoyt's Avatar
Default JE990
Originally Posted by john curl View Post
Anything less complex than a Jensen 990 is a joke, and not worthy of consideration. We are looking for EXCELLENT circuits that we would use in the best audio equipment available today.
One of the 990's best characteristics was it's stability into (relatively) difficult loads. It was designed by Deane (RIP) to drive his transformers (albeit he recommended output isolators) so it had to be stable. The 990 was quiet enough to make a high-end MM RIAA preamp in 1988, as executed in the PR&E (Pacific Recorders & Engineering) TX990, still a great-performing pre (see attached pix)
Howie
Howard Hoyt
CE - WXYC-FM 89.3
UNC Chapel Hill, NC
www.wxyc.org
1st on the internet
As a footnote, I worked tangentially with Bill Whitlock (now Jensen Pres) at Capitol Records when they decided to ditch their own digital duplication bin and install our DAAD system. He is one of the brightest engineers I have ever worked with. He came from Quad-8 (as did Deane) interestingly enough, since a Quad-8 amp schematic has just been posted...
Old 23rd August 2012, 05:02 PM   #88
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Samuel Groner has shown the most popular topologies for Opamps.
Old 23rd August 2012, 05:03 PM   #89
Sorry, two are missing.
Old 23rd August 2012, 05:06 PM   #90
Here we go...
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 07:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 04:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 01:52 PM
Copyright ©1999-2017 diyAudio
