Discrete Opamp Open Design
Old 3rd September 2012, 06:57 PM   #641
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by RNMarsh View Post
PS - On the mid-level of gnfb circuit without dc servo... some have wondered just how stable over the long term it could be. After a year of service, I measured the dc offset at the output again and it is exactly where i left it a year ago..... .00x + or - a couple mV. -RNM
Gee, I thought you meant temperature stability we usually go 0 to 70C min. Even my Hafler DH220 was only a few mV off after a year with a pot across two diodes for trim (at room temp).
I don't really relate to these standards of performance, if you have some need to flog your circuit go for it.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 3rd September 2012, 07:18 PM   #642
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Default Enough about you -
Not really. Comments trigger thought and so i write them down. I dont sell any IC's or have any stake in IC or opamps or any other topology. btw - I have already commented on its temp stability range as well..... there hasnt been shown any change in the short term and now shown in the long term drift, either.
Or, do you mean --- Enough About You. Let's talk About Me. ?
Old 3rd September 2012, 07:38 PM   #643
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by coluke View Post
Never say never - current-mode open-loop topologies are indeed capable of very low THD: I've built and tested a HP amplifier based on a pretty standard architecture (diamond in - transimpedance gain stage - high current diamond out) whose THD is in the -100 dB range (low order only) @ 1 kHz, 0 dBV into 30 ohm. And it sounds very good, too , but it is by far too much complex to be mentioned here (about 20 BJTs - basically a discrete CFA). You can easily convert it to closed-loop, and that's the reason why I gave a try to this architecture.
I think the Ayre KX-R is based on the same concept.
L.
How can you claim no feedback when you used Diamond buffers with 100% negative feedbacks?
Being a student I got a bottle of cognac by making an amp on emitter followers only, with auto-transformer in the middle. 100% feedback, unity-gain stages.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 3rd September 2012, 07:43 PM   #644
RNMarsh's Avatar
[The Hafler DH220 is cap coupled in the feedback via 470mfd bipolar. It also isnt jFET on the input; Much easier to be dc stable with bipolar]
Old 3rd September 2012, 08:04 PM   #645
coluke is offline coluke  Italy
I meant no * global * feedback. But tons of local feedback, of course; and Sziklai pairs in the output diamond, too - actually I have nothing against Harold Black, but the performances of the CF architecture I did mention (which is more or less the standard one - you can see it in an awful lot of monolithic CFAs) are quite amazing.
L.
Old 3rd September 2012, 08:26 PM   #646
RNMarsh's Avatar
Default CFA
L.
Can you give examples of good discrete CFA designs/schematics with the output stage similar to your idea?
Old 3rd September 2012, 08:33 PM   #647
Folks here know me well enough I have nothing to sell and could care less what you think of me. The truth is you do have something to sell unless your web site is just for show.
Old 3rd September 2012, 08:48 PM   #648
BrianL is offline BrianL  United States
Scott,
Don't you mean "couldn't care less"... ;-)
bel
Old 3rd September 2012, 08:51 PM   #649
Originally Posted by BrianL View Post
Scott,
I guess, God is in the details.
Old 3rd September 2012, 08:56 PM   #650
Wavebourn's Avatar
Here you go, from this thread several pages ago:
Here is one more topology that can be used in custom discrete opamp as an output stage. Actually, it is complementary symmetric opamp with 100% feedback. As drawn, it works in class AB, but output devices do not go through cut-off. If to remove diode-resistor shortening networks in tails and decrease values of resistors in tails it works in class A.
Diodes in current mirrors can be replaced by transistors. But not diodes in right sides of diffpairs: transistors have low base-emitter breakdown voltage, and when the amp goes from voltage follower mode to current amplifier mode (shortened output, or too low load impedance) transistors would be fried.
Resistors in tails instead of current sources are there on purpose: max current depends on output signal level.
For line level current mirrors better to be more balanced: R5 and R6 decreased, R9 and R10 increased. And transistors in places of D1 and D6.
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
