Discrete Opamp Open Design
Old 31st August 2012, 05:50 AM   #581
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Default Do good compliments exist?
Originally Posted by EUVL View Post
> This is not correct: 2x2SK117=2x2SK209=2SK2145=2SK3320
Was a typo from me in a rush. Sorry for my blunder.
2SK117 = 2SK209 = 2SK880 = 1/2*2SK2145 = 1/2*2SK3320
2SK246 = 2SK208 = 2SK879
2SJ103 = 2SJ106
Patrick
What is the short list of good complimentary jFETs??
Thx - RNM
Old 31st August 2012, 06:39 AM   #582
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by elektroj View Post
Wavebourn, do you mean by that circuit similar to Widlar Op-Amp Current Source?
I am not familiar with such terminology. I mean, recording head should be driven my current source, not voltage source.
The Devil is not so terrible as his math model is!
Old 31st August 2012, 07:00 AM   #583
john curl is offline john curl  United States
john curl's Avatar
Yes, Widlar current source is optimum.
"Condemnation without Examination is Prejudice"
Old 31st August 2012, 07:01 AM   #584
john curl's Avatar
My load was 1mH.
Old 31st August 2012, 02:43 PM   #585
john curl's Avatar
I take back my opinion, although the Widlar current source is OK, I used something better do current drive my record heads. I don't know the exact origin of the circuit, but it 'stumped' R.G.Meyer, when I described it to him and he drew it on the blackboard in class.
Old 31st August 2012, 05:45 PM   #586
scott wurcer is online now scott wurcer  United States
scott wurcer's Avatar
Originally Posted by RNMarsh View Post
Id set at the zero temp - they work fairly well.
From the datasheet that's about 500uA. With 1K between the sources you would only have an average of .25V Vgs, so you can't use a lot of the distribution.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 31st August 2012, 05:53 PM   #587
bcarso is offline bcarso  United States
diyAudio Member RIP
Thx - RNM
I'd say there are about ... none. The only P channel devices still in production that I know of are from two rather-low-performance processes, that from which the 5460 is drawn, and that from which the 5114 is pulled. Low gm, highish noise, low breakdown voltages.
There is of course stock here and there of the 2SJ74, the nominal complement to the 2SK170, and the even rarer P channel dual the 2SJ109 (complement to the discontinued 2SK389 dual). And at that the complementarity was focused on the transconductance, at the expense of capacitances and undoubtedly an even more extravagant die area. It is no surprise that Toshiba found them unprofitable to maintain.
On the other hand, partly because of the Benjamin Franklin direction of current flow there continues to be substantial development and availability of P channel DMOS with a reasonable range of properties. As remarked, there are no guarantees on noise, particularly at low frequencies, so in general such parts and their N channel cousins are not recommended for low noise early stages where the noise gain is high. As cascoding parts however, since the preceding transistor is usually possessed of a fairly high output Z, they can function reasonably well, except for the requirement of a gate bias for the enhancement-mode devices. Since the d.c. current at the DMOS gate is negligible this bias source can be a photovoltaic one or a battery, although this will hardly be very compact. I'm not sure if there are any depletion-mode PMOS devices like the NMOS DN2450 and similar parts, although if one were to order a million pieces maybe Supertex could be persuaded to try to make them
EDIT: Of course a folded cascode gets rid of the PMOS biasing voltage problem, but the pullup resistor that supplies current to the input device and the PMOS device has to be large enough to make the voltage noise of the PMOS have a small effect. This costs voltage and power dissipation. The resistor can be replaced with a current source, although still some volts are needed and the noise contribution from that source will be more than that of a resistor spanning the same available voltage.
Old 31st August 2012, 06:20 PM   #588
Sorry Dick I misread the schematic (I read 51.1 Ohms on the penciled in values), you were aiming at 800uA but does not look too close.
Old 31st August 2012, 06:23 PM   #589
The Fairchild PFET's are 'very' noisey.
Old 31st August 2012, 07:02 PM   #590
diyAudio Member RIP
Indeed --- I used to wonder if the old databook values could possibly be that bad. Unfortunately, they appear to be about right. Ouch!
The attached is from an ancient National Semi databook, and the process 89 is from which the 2N5460-61-62 parts are sourced. The somewhat larger die from Process 88 is a good deal better, but both fall woefully short of the noise performance predicted by Van der Ziel, even at 100kHz, where the curves are beginning to level off.
In light of this, the 2SJ74 etc. was quite an achievement.
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 07:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 04:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 01:52 PM
Copyright ©1999-2017 diyAudio
