Discrete Opamp Open Design Discrete Opamp Open Design - Page 55 - diyAudio
Old 30th August 2012, 04:28 PM   #541
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by hitsware View Post
> Except it's not an op-amp and not an easy drop in in lots of places.
> Does not scale easily to phono use either.
Isn't it a ' current feedback ' op-amp ?
Sort of, the performance of the non-inverting input would be problematic in many places. Those PFET's are pretty noisey too sort of like the J177's I looked at.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 30th August 2012, 04:35 PM   #542
Wavebourn is offline Wavebourn  United States
Wavebourn's Avatar
Opamp is like universal wrench: seems flexible, but can't fit everywhere.
The Devil is not so terrible as his math model is!
Old 30th August 2012, 04:35 PM   #543
bcarso is offline bcarso  United States
diyAudio Member RIP
Default 2145 gate leakage measurement
Originally Posted by bcarso View Post
EDIT: I'll try to do a better measurement of Ig after some more sleep. I could infer it by guessing at what the 10M-loaded follower gain is and hence what the effective laod R was, but a more direct measurement with a high-meg R is also possible with some attention given to shielding. I'll bet it is a good deal less than a nA (which is the max spec for the conventional hookup).
OK: with a much-improved setup, chopping the input gate-to-common resistor between 2.7kohm and 2Gohm, I see output delta V of only 800uV, indicating Ig of only 400fA. Much bettah! This is with +9V on the upper drain, -9V on the lower Idss-connected current sink. Drain current is 2.73mA for this setup.
Knew that Victoreen resistor would come in handy someday.
With this result I'm leaning still further toward the theory that these are separate chips inside.
Old 30th August 2012, 04:37 PM   #544
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Originally Posted by john curl View Post
Well Richard's example gives us a lot of leeway to use a simple differential pair, so long as we can trim. For example:
Of course, trimming can get you zero offset at the output. but, is it thermally stable - no drift with time/temp? That is the subject brought up and being discussed by others here.... getting both..... without a dc servo circuit added. :-)
Old 30th August 2012, 04:39 PM   #545
stinius is offline stinius
Except it's not an op-amp and not an easy drop in in lots of places. Does not scale easily to phono use either.
Scott
I'm not sure that Dick is saying that it's an op amp, I guess this is the RNM headphone amp.
It looks like an early current feedback amp, but with comp jfets at the input.
As I see it it is more like a buffer with some gain and cfb.
With local compensation and used close to unity gain it could be designed as a OK ops for the "No Global NFB folks", (use the available gain to lower THD and output Z).
Then the "frontend" wich is what most here are discussing could do the voltage amplification and the current is left to the "buffer".
Or it could be used as a part in a "nested" fb design.
(a bit Krill)
Cheers
Stein
Old 30th August 2012, 04:46 PM   #546
john curl is offline john curl  United States
john curl's Avatar
Richard, with the proper monolithic dual jfet pair, the drift would be negligible after manual DC trimming.
"Condemnation without Examination is Prejudice"
Old 30th August 2012, 04:48 PM   #547
RNMarsh's Avatar
All true. Just met my goals for audio line stage or headphone amplifier.
Main point -- no servo and thermally stable. And, cheap and simple to make. Why is it thermally so stable? Does answere have utility in opamp?
Old 30th August 2012, 04:51 PM   #548
RNMarsh's Avatar
John, could you get same results with your toplogy in current use w/o dc servo? You indicated you wanted the external dc servo [to allow optimum performance without compromise of circuit?.] That isnt clear to me.
I know trimmer contacts causes trouble but ignoring that for a second -- if you unbalance diff stage in some topologies, the thd goes up.... at least in low-modest gnfb designs. Need dc trim that doesnt do that and still be thermally stable.
With dc trim shown in my simple circuit... it wasnt needed in practice as offset was so close without it due to matching devices. It is thermally stable into 30 Ohm loads. Better performance into higher Z loads, of course.
Is it possible that many topologies dont need dc servo if properly balanced?
What about opamp circuit of conventional appl as Scott points out. Can it be done there? We shall see. -RNM
PS - I just put up the example that dc servo isnt always needed and to answere the reader about my whinning on the matter and not showing anything myself. It makes a point. Gets the job done. (BTW - other popular jFEt were also tried with similar results).
Old 30th August 2012, 04:56 PM   #549
N and P together! Where?
Old 30th August 2012, 05:00 PM   #550
john curl's Avatar
Look before you criticize, Scott. The discrete 'op amp' that I recently put up was designed in 1977, before I started using servos. That is WHY it has a DC offset adjust.
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2017 diyAudio
