Discrete Opamp Open Design
Old 29th August 2012, 06:27 AM   #471
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
No, Hfe isn't one of the fundamentals of transistor operation, there's significant process variation.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 29th August 2012, 06:34 AM   #472
Wavebourn is online now Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by EUVL View Post
1/22mS = 46 ohm.
And 22mS comes from first page of data sheet :
2SK170?Junction FETs (Single/Dual)?TOSHIBA Semiconductor & Storage Products Company
Mr. Wavebourn is assuming the NPN has zero emitter resistance, which is of course not 100% true.
It depends on the bias.
No, Mr Wavebourn does not assume that emitter resistance is zero, as well as that beta is infinite. But I assume that 47K would be close enough.
The Devil is not so terrible as his math model is!
Old 29th August 2012, 06:45 AM   #473
EUVL is offline EUVL  Europe
47 ohm I guess, not quite so close to 47k.
xen-audio.com
Old 29th August 2012, 06:46 AM   #474
Wavebourn's Avatar
Yes, sorry for the typo.
Old 29th August 2012, 07:01 AM   #475
hitsware is offline hitsware
Pardon my (evedently) **** poor education on the subject.
Old 29th August 2012, 07:03 AM   #476
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Default Spec goal in design -
Here is were some spec numbers came from as goal - see line #279 of Marsh headphone amp forum.
Old 29th August 2012, 07:03 AM   #477
47 Ohm or 47 kOhm ?
Old 29th August 2012, 07:05 AM   #478
abraxalito's Avatar
But you have been educated on this subject - you yourself said that 'the enlightened know transistors are voltage controlled' That Hfe isn't well defined is a corollary of this I believe.
Old 29th August 2012, 07:59 AM   #479
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by scott wurcer View Post
At 20k the base current re-capture lowers the open-loop distortion by 30dB.
Cute. Brings memories of Malcolm Hawksford.
So far the only real novelty in the barrage of 'me-too' circuitry
jan
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 29th August 2012, 08:36 AM   #480
bcarso is offline bcarso  United States
diyAudio Member RIP
jan
This is a critical tool, and as I and Jung have shown elsewhere, dates back well before Hawksford to Boxall and Aldridge. Walt is working on the all-JFET history so I won't go into that here.
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 07:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 04:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 01:52 PM
Copyright ©1999-2017 diyAudio
