Discrete Opamp Open Design
Old 22nd August 2012, 11:06 PM   #21
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Originally Posted by dirkwright View Post
We need a prize.
Fame and fortune isnt enough?
Old 22nd August 2012, 11:10 PM   #22
RNMarsh's Avatar
PS Waveb --- that is NOT discrete circuitry. We mean no IC's. As in -- make an opamp without the IC. Then it would be compared to IC form. A version of the AD627 with individual parts - no IC's.
Old 22nd August 2012, 11:21 PM   #23
bcarso is offline bcarso  United States
diyAudio Member RIP
I doubt there will be anything remotely approaching a consensus on what this is supposed to be. It's hardly worth the effort. I see the "religious" factions circling already.
But if it spaws umpteen different designs, some of which may actually be built and tested, the efforts might not be all bad.
I'm reminded of the Monty Python Flying Circus sketch about the lethal joke. At one point, after many had died trying to read the joke, teams worked on it in isolation and with individuals being assigned to only one word each. Perhaps this needs to resemble that. The so-called VAS people won't know about the input stage efforts, nor the output buffer. Strictly on a need-to-know basis here
Old 22nd August 2012, 11:22 PM   #24
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
Is this like building a PC or Apple desktop with vacuum tubes........ Can you really outperform a production opamp, and that includes any opamp no cost constraints?
Old 22nd August 2012, 11:38 PM   #25
diyAudio Member RIP
Oh certainly [EDIT: at least at audio bandwidths]. "...it happens all the time." But perhaps not with eight active devices. If I were to do this I'd throw out that constraint to begin with. Again (as I remarked in the Blowtorch thread) we need to ask what the advantages are of ICs, and although not discussed there, what kinds of things can we do with discretes when unencumbered with the integration constraints.
The restriction to parts that are still readily available is a bi%ch though.
Old 22nd August 2012, 11:41 PM   #26
fas42 is offline fas42  Australia
Banned
What's wrong with having a competition between 2 camps: a "pure" discrete opamp, vs. a hybrid using ICs, which then sounds "better" ... heh, heh ...
Frank
Old 22nd August 2012, 11:53 PM   #27
RNMarsh's Avatar
Frank
I'm interested in all but more interested in Scott doing a discrete (with help choosing transistors etc) similar to IC opamp 627, first. Because we need to answere if a discrete sounds the same or better than IC. he does/did opamps and has intimate knowledge of the 627 so who better to try a discrete version?
Lets help him do that. -RNM
Old 22nd August 2012, 11:58 PM   #28
dirkwright is offline dirkwright  United States
dirkwright's Avatar
It must be competitive with what is out there already.
It is less of a challenge to do better with more.
[ I could allow cascoding to be considered as a single transistor if it cant be done otherwise. Current sources, diodes might not be counted]
BUT - Scott wanted to do a discrete version for audio of the 627 opamp and that is fine with me. I dont want to start doing something Scott did not say he wanted to do.
A discrete opamp circuit of 627 opamp would be nice for others to compare with the integrated version.
-RNM
So the 627 opamp can drive 30 ohms no problem? I mean, we're talking about a headphone amplifier, not an opamp.
Old 23rd August 2012, 12:00 AM   #29
dirkwright's Avatar
Originally Posted by bcarso View Post
...although not discussed there, what kinds of things can we do with discretes when unencumbered with the integration constraints.
I guess higher voltages and currents? At least in the opamp world anyway.
Old 23rd August 2012, 12:02 AM   #30
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
Richard, AD627 is micropower opamp. Do you mean ADA4627, the substitute for OPA627?
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
