Discrete Opamp Open Design
Old 23rd August 2013, 10:16 PM   #2951
jcx is offline jcx  United States
There is a legend in Africa that speculates that elder elephants knowing that their death was imminent left their herds and traveled to a place known as the ...
Old 23rd August 2013, 11:12 PM   #2952
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
jcx,
The Boneyard! It isn't even that some of these things are small as much as some of us are getting blind as we age! I know I will have to put on my magnifying lenses to work on a smd or else forget about it. I just haven't had to deal with any so no experience. Not really afraid to start just haven't had the opportunity or the need up to now.
Old 24th August 2013, 12:04 AM   #2953
rsavas is offline rsavas  Canada
My first job out of college was at Motorola, it must have been one of the first SMT production lines in N/A, ~1985, had a FR4 and a ceramic substrate hybrid line, running in parallel.
One day a green ME did a test around lunch time, put an FR4 pcb through the hybrid line, smoked to whole place out, people sick/fire dept etc, got to go home early that day. :-)
Yes magnification is the answer.
All for SMT, for many assy's, it really is a mix of SM/TH. Paste/glue/reflow/wave/back-load etc.
P.S. still got parts I picked off the floor while fixing the pick/place machine. Now have a LCR meter, so can finally sort them MLC caps out.
Old 25th August 2013, 01:37 PM   #2954
grhughes is offline grhughes  United States
grhughes's Avatar
All you young guys with perfect vision go for SMT. My eyes are not what they used to be. Personally I don't relish chasing a SMT part around a 1 inch square board with while holding a magnifying glass or wearing uncompfortable visors or peering through a microscope. I haven't built anything since about 1980 and I have a drawer full of matched 2n4401/03 in TO92 and I don't want to go through that pain of matching again. I would rather have holes to anchor the part before I solder it. Call me a dinosaur or whatever. I'll probably only build four of Scott's preamps and that will be it, so why invest in all the paraphenalia I would need for SMT. So please consider a thru hole board for us aging dinosaurs, PLEASE. Ray
" Polarities are seldom aware of their polarness." Prospero
Old 25th August 2013, 03:23 PM   #2955
bcarso is offline bcarso  United States
diyAudio Member RIP
The advantages of SM are manifold. It's possible to get performance at high frequencies that simply isn't accessible with radial/axial components. But they are difficult to work with. You can however sometimes get subassemblies with SM on little boards that convert, say an SO-8 to an 8-pin DIP. But you lose performance advantages with the added parasitic inductances (in particular).
I designed an elaborate hybrid analog and digital board for Epson America, for a home theater system, which went into the motorized screen and was both a motor controller and IR receiver/processor. I was rather pleased with how I managed to infer the motor condition, including its internal and otherwise inaccessible limit switches, looking at phase and transmitting signals across a galvanic barrier. I brought in an early version to show them, and the thing that they were impressed with is how I'd managed to put it together, as there were a lot of surface mount parts
Old 26th August 2013, 02:33 PM   #2956
If you do the math, I ain't young (54) but god did bless me with being very myopic, which in the case of small, is very good. Must realize that SMT is geared for automated assembly, period.
I have done some big pcb's, where I designed, gave to fab, got an assembled pcb back, with some BGA pkg's used, so it really is the economics of scale. If everything worked, as it should, I did not even have to touch a soldering iron.
Yes as DIY, THT is the best for all concerned, but I want to use a BF862 or one of those duals in a SOT-363? and NXP don't want to bother with a THT pkg, so it is, use what ya got and most possibly limit yourself, or get with the times.
Actually those clowns, finally standardized on the pin out for a bjt/fet in a SOT-23, where as, for say a T0-92, it is scattered about and thus is a PITA.
Awful shame that this SMT issue limits many a man's horizons, so that ends the story for me.
Rick
Old 26th August 2013, 04:52 PM   #2957
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
I am curious, why this project would end that streak? If a modern monolithic opamp hasnt ended this trend already, why should this?
Old 26th August 2013, 06:03 PM   #2958
grhughes's Avatar
I'm retired now. All my kids have grown and out of the house and I have time to upgrade my gear that I built in 1980; replace all the electrolytics, etc. Is that enough of an answer? Ray
Old 26th August 2013, 06:18 PM   #2959
diyAudio Member RIP
At least most electrolytics will be large enough to be seen.
I finally had to replace one in an NAD3020. Considering I'd used the amp since circa 1980 as well, I hardly was surprised. And it wasn't even one of the big bulk caps, rather one of the auxiliary higher-voltage rail ones. Of course I changed both aux rail ones together. I looked at the ripple on the main rails and it was still just fine, so I decided not to bother with those. Of course the switches and the volume pot have long ago gone south, so I simply run into the power amp input on the back.
Old 26th August 2013, 06:32 PM   #2960
Past Deoxit and disassemble/clean with eraser etc?
Parts not avail either, so need to jump on the S/S, relay and CS3318 bandwagon.
Need a pre-amp, with no pots, switches, in the sig path, got one for sale :-)
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
