Discrete Opamp Open Design
Old 16th March 2013, 06:37 PM   #2841
myhrrhleine is offline myhrrhleine  Belize
myhrrhleine's Avatar
Originally Posted by RNMarsh View Post
Well then, let me throw this out there --->
One of the reasons for going low gnfb -in my mind- wa to get a constant amount of fb at all frequencies. back in the day, I didnt have such good test equipment for measuring distortion.
I thought that the way sound was described sort of followed the thd curve. --- best at low freqs and progressively worse as the freqs when higher.... that high freq rise at the top end. Still a characteristic of many amps -- pre or power. As we know there are many mechanisms at work.
But limiting this to just the thd and amount of feedback here -- What if -- the harmonic structure did not change with freq ?? What ever the relationship between harmonics at low or mid was the same at the high freqs? Same ratios etc.
Wouldnt that have a sameness to the sound across the audible band? No more, the mids sound this way and the highs sound that way. The character would be the same/similar.
In fact, that is what you get in test performance and in listening results. If the harmonics are high enough to hear or the chain/system has harmonics high enough levels to hear differences. there is no other way to get this kind of favorable result (is there?)... assuming a falling open loop within audio feq band and varying feedback margins/amount of etal.
Thx-RNMarsh
You are right about the sound, however there is a different cause than harmonic amplitude.
[Grasshopper]:Old man, how is it that you hear these things?
[master]:Young man, how is it that you do not?
Old 16th March 2013, 09:29 PM   #2842
dadod is offline dadod  Croatia
dadod's Avatar
Thx-RNMarsh
Do you think that an amp with the loop gain like this would sound better?
Damir
Old 16th March 2013, 09:51 PM   #2843
magnoman is offline magnoman  United States
But music or speech isn't white. I would think you'd have to take into account the power spectrum and further weight the more audible frequencies.
Just dont see the down side of having more loop gain where there is more energy hence higher signal amplitudes and increased distortion.
-Antonio
Old 16th March 2013, 10:05 PM   #2844
dadod's Avatar
I just ask a questions. Here are FFTs for 20Hz, 1kHz, 10kHz and 20kHz for the same output voltage(60 Vpp).
Damir
Old 17th March 2013, 05:38 AM   #2845
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
When the same amount of gnfb is used at all freqs, the distortion harmonics are alike at all freqs.; Same level and number and relationship/ratio. I believe this type of distortion pattern is well accepted as best sounding.
As I have said in earlier comments -- levels below -100dB are not audible to me and would be a desireable goal for all parts of the recording/playback system - keeping the total accumilated system thd below audibility.
Sorry but SIMs dont count. Only actual, live operating circuits and systems.
Here is a moderate gnfb line level amp that has the same THD and same harmonic structure at all freqs in the BW of interest. Only 2H and 3H. The important issue is that it looks the same at any freq tested...same level and number of harmonics and relative levels to one another.
Anyway, this characteristic is why, IMO, amps with low or no gnfb are liked by so many people.
Thx-RNMarsh
Old 17th March 2013, 06:32 AM   #2846
dadod's Avatar
But somewhere we have to start when design, and then do the measurement on the built amp. I hope you do not advocate to design without simulation?
Damir
Old 17th March 2013, 07:37 AM   #2847
Samuel Groner is offline Samuel Groner  Switzerland
As noted by a previous poster, you (and the many others who support this theory) miss that the frequency spectrum of music is not white. A circuit with measured frequency-independent distortion characteristics will in fact distort the bass range of real music more than the high-frequency portion.
Samuel
Old 17th March 2013, 07:52 AM   #2848
RNMarsh's Avatar
Seems reasonable. However, there is also a continuity that doesnt exist in any other type of distortion pattern. A sameness of character from top to bottom. What I am describing does not sound/heard as you describe.... worse in the bass. So maybe I am not characterizing it well enough. or weighting is something that lends a more constant or even quality. Well, its been easy to hear a pattern of distortion change that is uncharacteristci sounding from the falling open-loop gain etc and its distortion pattern. Worse or better.... it is different from typical pattern often found..... A flat thd plot vs one that rises at the higher freqs.
Thx-RNmarsh
Old 17th March 2013, 11:22 AM   #2849
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
What if the rising thd plot still is below -100dB at the highest frequency you are able to perceive ?
Old 17th March 2013, 04:57 PM   #2850
RNMarsh's Avatar
Then you are on double-safe ground. And, would focus on construction, parts selection, shielding, grounding, interfacing, impedances, loading, controls, power supply, etc to not spoil the pristine amp. The goal then being to have the entire system -from source to speaker - not accumulate any issues that would intrude.
-Thx-RNMarsh
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
