Discrete Opamp Open Design
Old 7th January 2013, 01:45 PM   #2581
staccatiss is offline staccatiss  Germany
I checked it out, and was rather disappointed when I read that:
The greatest benefit from multiple cores is achieved when running Monte Carlo analyses and other multiple analysis modes. This applies to both SIMetrix and SIMPLIS simulators. For this application, typical performance benefit of about 75% of the core count can be achieved. So for 4 cores a Monte Carlo run may execute about 3 times faster. The SIMetrix simulator can also exploit multiple cores to gain a speedup for single runs, but the performance benefit achieved is much more modest and typically there is little benefit in having more than about 4 cores
More than 4 cores are thus not needed for single runs in TRAN :-(
I stay with MicroCap10.
Originally Posted by PHEONIX View Post
Hello Richard,
If you want a good simulator that will run in linux try simetrix at the link below, its available in various versions and is a serious simulator. It also has the option of being command line driven.
Analog, mixed signal circuit simulation software tool, SIMetrix, SIMPLIS, Micron VX, DVM
In my opinion its better than Microcap because its unaided convergence is superior which means it crashes fewer times on circuit simultions. But Microcap is an excellent simulator and there are many users on this forum who are quite productive with it Edmond Stuart comes to mind.
Arthur
Old 8th January 2013, 05:52 PM   #2582
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
4 cores and 3X faster.... but also with fewer hangups. So 8 cores sounds about right for me. As cost of cores comes down and/or becomes more popular, the software developers make further improvements. So a few more cores is a good thing. Guess I'm looking for an 8 core for now and for its future advantage. Thx-RNMarsh
Old 10th January 2013, 03:18 PM   #2583
grhughes is offline grhughes  United States
grhughes's Avatar
For J7 and J8, can I use 2n4416A/mpf3821? I have a bunch already matched. Thanks, Ray
" Polarities are seldom aware of their polarness." Prospero
Old 11th January 2013, 12:50 AM   #2584
dchisholm is offline dchisholm  United States
dchisholm's Avatar
I presume you are referring to J17 and J18 (the input JFET's) in the diagram attached to Post 2409.
The MPF3821's specified Idss is too low (0.5 mA guaranteed minimum) to use in this circuit without extensive redesign of the entire biasing scheme. Those input devices require an Idss of AT LEAST 5.0 mA.
The 2N4416A satisfies the Idss requirement, but the forward transconductance is lower than the suggested BF862 by a factor of about 8:1. Without checking it out in simulation it's probably safe to say that the amplifier WILL amplify, but the overall performance will be measurably lower.
One interesting characteristic of this architecture that shows up in several posts along this thread is that the design seems to be relatively immune to variations among the active devices, so it may be interesting to try a pair of 2N4416A's just for the experience.
Dale
Old 11th January 2013, 03:16 AM   #2585
grhughes's Avatar
"it may be interesting to try a pair of 2N4416A's just for the experience."
Thanks! I was thinking about the upper cascode devices rather than the input jefets I'll stick with the recommended BF862 devices. I just had these on hand. Ray
Old 11th January 2013, 04:17 AM   #2586
RNMarsh's Avatar
Dale
is it the architecture or the very high feedback that makes it insensitive to device variations? How much does each contribute to that characteristic? Thx-RNMarsh
Old 11th January 2013, 04:49 AM   #2587
jcx is offline jcx  United States
well you could try Bode's sensitivity analysis - likely even taught in EE programs when you were in college
Cherry has a good paper on the subject that takes a step into nonlinearity contributions (article tests the developed estimation math against actual Hardware)
Cherry’s “ESTIMATES OF NONLINEAR DISTORTION IN FEEDBACK AMPLIFIERS” JAES V48#4 2000 p299-313 provides a method of calculating individual component distortion mechanisms contribution to overall distortion of a amplifier, more importantly it gives a intellectual framework for reasoning about distortion and feedback in a feedback amplifier.
Old 11th January 2013, 05:31 AM   #2588
RNMarsh's Avatar
nah. I dont want to do that. i just want an answere from one who already knows the general answere for this topology. The assertion was that it was the topology, as i understood it. Did one do those calc against other topologies? For example in most any topology enough degeneration R will give similar insensitity to device parameters ... regardless of topologiy. A lot of gnfb can do the same thing as far as end results (distortion) is concerned... again, regardless of topology. I'm just messin' with ya... making a trivial point is all.
Thx-RNMarsh
Old 11th January 2013, 02:04 PM   #2589
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
The biggest problem with the 4416 is the highish Vp so cascoding it is less simple. The pairing of a low Vp input device and a high Vp cascode is the easiest (just tie the gate back to the source).
The gm at 5mA of the 4416 is also lower, but the intent of this design was to get the most out of a single gm-C gain stage so there is latitude to just adjust C and see what you get. To repeat one of the points of a discrete circuit is the ability to custom compensate for each location.
I tried in the simplest way to compensate for base current errors and dynamic Ccb errors in the bipolars that's why I think there is some desensitivity to device selection (within limits of course).
Little slow right now since I seem to have a touch of the flu but I got the output board through the reflow and all seems well, bias trimmed right up and hope to repeat the open-loop performance verification.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 12th January 2013, 04:41 PM   #2590
grhughes's Avatar
Thanks Scott! Take care of that flu! Ray
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 07:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 04:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 01:52 PM
