Discrete Opamp Open Design
Old 24th August 2012, 08:13 PM   #221
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by scott wurcer View Post
Typically they're scribed on a sheet of heat activated sticky plastic and stretched. Now they would probably use a vacuum pencil pick and place after that.
The same die dual issue would be what is the substrate, I thought it might be the back gate so isolated duals would have to be two die. We always bought them that way.
EDIT Sorry EUVL the FET's were drawn funny, and some symbols show the arrow at the drain.
I ran across a company in Utah making four-terminal JFETs with front and back gates. They seemed to be focusing on the X-ray spectroscopy biz to begin with, branched out into FETs. One "package" shown was a "nailhead". Your business to select a low-loss dielectric
Old 24th August 2012, 08:22 PM   #222
coluke is offline coluke  Italy
Originally Posted by bcarso View Post
The paper was in the Hewlett-Packard Journal (...)
February 1971 issue: http://www.hpl.hp.com/hpjournal/pdfs...Fs/1971-02.pdf
L.
Old 24th August 2012, 08:29 PM   #223
diyAudio Member RIP
Originally Posted by coluke View Post
How nice that is available! Thanks for finding it.
Brad
Old 24th August 2012, 08:43 PM   #224
I must confess I'm addicted to HP journal
L.
Old 24th August 2012, 08:44 PM   #225
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Brad
All math no simulator, interesting look at old school analysis. The old Teledyne publications were also good in this respect.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 24th August 2012, 08:55 PM   #226
On a 9100A - a ~20 kg RPN programmable calculator with a 196 steps wide program memory
L.
Old 24th August 2012, 09:31 PM   #227
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Scott -- how would you modify your input to apply negative common-mode feedback?
Old 24th August 2012, 09:37 PM   #228
RNMarsh's Avatar
Are there dual gate jFET's similar to a dual gate MOSFET?
-RNM
Old 24th August 2012, 10:07 PM   #229
diyAudio Member RIP
-RNM
No, those were front and back gates. Not a cascode structure.
EDIT: Actually I think there were some integrated cascode duals, but they didn't being out all the connections.
Old 24th August 2012, 10:11 PM   #230
bear is offline bear
expert in tautology
bear's Avatar
2SK2145, the ratings/specs are for devices in parallel operation or single devices?
Afaik not all jfets can be run "backwards"... most?
...then the question is the IDSS group 1/2 of the parallel IDSS or??
So, what is the application for a dual jfet with the sources tied together - or why not internally wire them in parallel and offer the device as a "single"?
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2017 diyAudio
