Discrete Opamp Open Design
Old 30th November 2012, 01:17 PM   #2281
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by jan.didden View Post
Neat! I think I need one...
Thanks for the heads-up guys!
jan
I've been evaluating the analog aspect of this, a few nits aside the biggest issue has been the response delay from the USB. You can't expect to stream two channels of 14 bits at 100MIPS to the disk.
The noise and crosstalk has been dealt with surprisingly well considering it all comes out that one bundle.
I'm not a digital guy but the logic analyser section looks like you could exercise just about any of the complicated chips that need an SPI port and a few dozen registers programmed before they do anything.
EDIT - Better idea, he might send you a free one for a one pager in the next issue.
I'll send you a contact, considering you're in the "trade" he might give you a code for the $99 US price. My code only works for 1 to an ADI address (we have had ebay issues with DSP development boards).
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 30th November 2012, 05:10 PM   #2282
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Yes I could do a review.
I don't think you'd want to stream that amount of data for any length of time.
What's the internal memory - does it do block transfers?
jan
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 30th November 2012, 06:55 PM   #2283
jan
Yes it saves blocks of data, which limits the FFT size you can post process. I was looking for some very large (>1M) contiguous data blocks.
Old 30th November 2012, 07:06 PM   #2284
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
Mixed Signal USB Oscilloscope | Cleverscope
Old 30th November 2012, 07:29 PM   #2285
benb is offline benb  United States
Certainly not over USB. One could wish for something with PCI or maybe even SATA (is it used for anything other than disk drives?) that would come close to that.
From the spec on analog inputs:
100 MSPS, 5 MHz bandwidth, up to 16k points/channel record length
And that's a shame, as it seems that more RAM wouldn't cost very much, but at the low price point I guess they pinch every penny.
I wonder about the bandwidth, I've seen similar specs (100MSPS, 5MHz where the advertised bandwidth is substantially lower than half the sample rate) on recent model scopes, and I have to ask, why isn't the bandwidth 50MHz? Is a wider bandwidth analog section really that much more expensive? I'm missing something.
Old 30th November 2012, 07:46 PM   #2286
We asked and got a round about answer dealing with aliasing (which is still a problem, my 100MHz fur showed up at 20MHz theoretically not possible). This was designed to sell a lot of units at the $99 price point, less than 1/2 the price of one of those tweezer meters.
Old 30th November 2012, 07:50 PM   #2287
Originally Posted by dimitri View Post
At an absolute min. of $1,200 (without function generator), OK.
Old 30th November 2012, 09:53 PM   #2288
PHEONIX is offline PHEONIX  Australia
Default USB scope
Hello Scott,
Can you clarify does this scope have differential inputs.
Arthur
Old 30th November 2012, 10:46 PM   #2289
Originally Posted by PHEONIX View Post
Hello Scott,
Arthur
Yes, true differential but the CMRR seems just OK.
Old 30th November 2012, 11:12 PM   #2290
kgrlee is offline kgrlee
It's almost certainly an oversampling ADC. All modern audio ADCs are oversampled and it looks like HF ADCs too.
Having a 5MHz measurement bandwidth and fs = 100MHz means you have more than 4 decades to go to -90dB and can use an easy (cheap) analogue filter. The 5MHz limit will probably be in software to match the analogue filter.
In fact, if the ADC doesn't have built in anti-aliasing, they may just let it droop to -90dB @ 100MHz. Makes it a little more useful though you can't get accurate results above 5MHz.
For Nyquist @ 1/2 fs, you need to go from 0dB @ Nyquist to -90dB in zero decades. You can't use software. That's an expensive analogue filter.
That's aliasing. Gotta put another 20c into the analogue filter.
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2017 diyAudio
