Discrete Opamp Open Design
Old 25th November 2012, 07:06 PM   #2201
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by Kindhornman View Post
Scott,
You just brought up a subject that you can obviously answer for me. When building a board and using rosin core solder should the hobbyist clean the boards after assembly? I have never done this and can say that I am not an EE so perhaps I have just been lucky or stupid and have never seen a failure because of flux. If I should indeed clean the boards what is the correct solvent to use? 1,1,1,T is long since not allowed and I wonder what is the best solvent for this purpose. Sorry for going off topic here, but I have often wondered if this is only a problem with the never non-lead based solders or all solders with a flux core. Built a Heathkit clock when I was a kid and it worked for almost 40 years before the digital display started to burn out. What is the failure mode action here with the flux?
In the very old days Freon used to be used. Brad Plunkett mentioned once that at UREI all one had to do to get rid of a grease stain on one's tie from lunch was to walk by the cleaning tank
Rosin flux is fairly nonreactive, and unless the board needs to be exceptionally low-leakage it is cleaned off primarily for cosmetic reasons (and as well it can conceal a poor metallurgical joint from visual inspection).
Old 25th November 2012, 08:10 PM   #2202
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Default It's coming --->
Originally Posted by scott wurcer View Post
Breadboard is finished, I need to give it a run in our flux cleaning tank and hope to do some measurements this week.
It won't be long now..... drum roll.
Old 25th November 2012, 08:16 PM   #2203
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Not only. If you manufacture for usage in tropics you have to remember that some molds eat rosin and poop acid. How do I know? I was taught to design and manufacture military equipment for very different conditions.
The Devil is not so terrible as his math model is!
Old 25th November 2012, 08:22 PM   #2204
diyAudio Member RIP
I'll use the same excuse I do when I inadvertently use offensive language (I thought Bruce Hofer was going to faint when I said "bull$hit" once, referring to someone's claims about typical noise of switchmode power supplies):
Sorry, I'm from California.
Old 25th November 2012, 08:26 PM   #2205
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Really! You should have heard Jim Williams and Bob Pease (well they were too).
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 25th November 2012, 08:28 PM   #2206
Wavebourn's Avatar
You need disclaimer, Brad: "Not designed for Florida"
Old 25th November 2012, 08:47 PM   #2207
diyAudio Member RIP
I could have that printed on my forehead too. I found Orlando barely tolerable in December. I can only imagine the summer.
Old 25th November 2012, 09:28 PM   #2208
john curl is offline john curl  United States
john curl's Avatar
Freon is the best, pure isopropyl alcohol and a brush can do. Serious designs remove the rosin.
"Condemnation without Examination is Prejudice"
Old 25th November 2012, 09:37 PM   #2209
fireworks is offline fireworks  Switzerland
Breadboard is finished, I need to give it a run in our flux cleaning tank and hope to do some measurements this week. Everyone else's efforts look good, though I would like to see at least one FET JE990 get built.
Can you post a picture of the breadboard ?
Old 26th November 2012, 12:30 AM   #2210
UGLY! Let me make some measurements first so maybe I can show ugly is beautiful.
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2017 diyAudio
