Discrete Opamp Open Design
Old 24th August 2012, 06:58 PM   #211
fitzfish is offline fitzfish  United States
Thanks Brad, Wayne.
Are we talking adjacent die? perhaps 5% or less matching?
Nice, small package for an smt discrete opamp LTP. Beats the SO8 from LSK.
Dave
Old 24th August 2012, 07:14 PM   #212
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by fitzfish View Post
Thanks Brad, Wayne.
Dave
Yes, they mention 2% for some of the parameters. A great idea; formerly they just sliced and diced and dumped into a big hopper before packaging, I guess. Having things off the same wafer was better than nothing, but this is a lot better.
Old 24th August 2012, 07:25 PM   #213
EUVL is offline EUVL  Europe
Yes, ideal part.
Same package as the BF862, but with two FETs on one die.
Noise a bit high, and could do with a bit more Yfs.
But then you can't have it all ......
Patrick
xen-audio.com
Old 24th August 2012, 07:28 PM   #214
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by EUVL View Post
Yes, ideal part.
Patrick
The data sheet I downloaded has the gates tied together, limited use?
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 24th August 2012, 07:33 PM   #215
Datasheet Version 2007-11-01, tied source and not tied gates ?
Still useful for input LTP ?
http://www.semicon.toshiba.co.jp/eng...485_13588.html
Patrick
xen-audio.com
Old 24th August 2012, 07:40 PM   #216
2SK3320. Same electrical spec.
Even smaller package.
2SK3320?Junction FETs (Single/Dual)?TOSHIBA Semiconductor & Storage Products Company
Patrick
xen-audio.com
Old 24th August 2012, 07:44 PM   #217
As most FETs are Drain / Source reversible, one can even use this as a Source Follower for the output stage.
For example :
Pin 1 = +Vs
Pin 2 = +Vout
Pin 3 = -Vs
Pin 4 = -Vs (via gate stopper)
Pin 5 = +Vin (via gate stopper)
Patrick
xen-audio.com
Old 24th August 2012, 07:48 PM   #218
jneutron is offline jneutron  United States
jneutron's Avatar
Dumped into a big hopper??? Shirley you jest..
I'da thunk either an expanded wafer, or waffle pack..
jn
Old 24th August 2012, 07:53 PM   #219
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Default good idea -
For example :
Pin 1 = +Vs
Pin 2 = +Vout
Pin 3 = -Vs
Patrick
That is a good concept... useful and practical suggestion.
Old 24th August 2012, 07:55 PM   #220
jn
Typically they're scribed on a sheet of heat activated sticky plastic and stretched. Now they would probably use a vacuum pencil pick and place after that.
The same die dual issue would be what is the substrate, I thought it might be the back gate so isolated duals would have to be two die. We always bought them that way.
EDIT Sorry EUVL the FET's were drawn funny, and some symbols show the arrow at the drain.
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
