Discrete Opamp Open Design
Old 3rd November 2012, 03:12 PM   #1971
Jay is offline Jay  Indonesia
Banned
Originally Posted by scott wurcer View Post
Open the LTSPICE model files you will notice that the 1N914 and 1N4148 have exactly (to 3 digits) the same values for most parameters which is obviously nonsense.
Hahaha I learned this issue the hard way
Old 3rd November 2012, 04:42 PM   #1972
bcarso is offline bcarso  United States
diyAudio Member RIP
What IS sometimes significant is that we might assume that 4148-style diodes have precisely the same I-V characteristics as diode-connected transistors. They do not, but it many applications the difference is of little importance. But the I-V curve for operation of the diode in the injection region, i.e., forward-biased significantly, will differ from that of a diode-connected transistor. This is discussed in many references* and for empirical data on differences among diodes see the Appendix E table in Pease's book Troubleshooting Analog Circuits, pp. 196-198. There is also a chapter 6, Understanding Diodes and Their Problems, which at least mentions "high-level injection" without showing the modification of the diode equation that it entails. Sadly, Pease omits the diode-connected transistor, and as well doesn't mention most of the manufacturers of the DUTs.
There was an Ideas for Design or some such years ago in which the author linearized a transistor gain stage by use of a diode. When I saw it I thought Ah, why not a diode-connected transistor? But it didn't work --- without declaring such, the circuit worked by virtue of the I-V curve differences, not their similarity
Brad
*including everyone's favorite compendium by Horowitz and Hill, except I can't locate it in the second edition right now.
See 4.4.4 and the rest of this reference where the modifying term eta, high injection, and the effects of series resistance are discussed in greater depth: The p-n diode current . The latter says you don't see much of the high-injection region separate from the series-resistance-dominated region, which is an assertion to be questioned Note that the ideal region is shown as below 550mV at room temperature for a typical small-signal diode, which is rarely where we operate them.
Old 3rd November 2012, 07:14 PM   #1973
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
A quick observation. Most folks have a little handheld VOM with a diode check function which works by forcing a current and measuring the drop. Simply test a 100 Ohm resistor and you know the test current (V/R) mine uses 1mA. You can use this to guestimate the saturation current of your batch of diodes/transistors from the diode equation and fine tune your sims.
I just grabbed 3 1N4148's from the junk bin and at 1mA they measured .653, .654, and .656 volts while my batch of 2N4401's measures about .655 volts connected as diodes.So clearly the stock models are off and this explains why Pete B's JE990 sim was so far off on bias, in fact the diodes are pretty close to the transistors.
EDIT - be careful not to heat the devices by holding them
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 3rd November 2012, 08:07 PM   #1974
kgrlee is offline kgrlee
Default Twitchy SW-OPA?
I've used 1n4148 in place of diode connected transistors for simple current mirrors in a production amp so have a lot of data on 2 cases.
One was at 0.8mA with BC556c and the other at 4mA with 2sc2362. In both cases, 1n4148 had significantly bigger drop. In the 4mA case, requiring a 180 resistor instead of 200 on the 2sc2362 emitter; ie 80mV
This bears on my investigation into twitchy SW-OPA. ricardo.txt which I uploaded in #1949 has BJT models from several gurus. I have 2 sets of c2240/a970 and also 4401/3.
Scott's c2240 has some 100mV more Vbe than his a970 at the same current.
Cordell's 4401/3 have closer Vbe than fas42's but for some reason results in a lot more THD in some circuits. I've looked at *.log which LTspice produces on .opt analysis cos this gives stuff which I pretend to unnerstan. The only difference which stands out is Ro whatever that is.
My own Jurassic experience with 2240/970 is that the models with closer Vbe are closer to real life.
I've also increased RB to more believable values in preparation for noise analysis but that shouldn't give 100mV errors. I'll take them out & see if that makes a diff.
Guru Wurcer, I'd still like to know if your instruction to adjust for 8mA applies to the output devices or just to the 4R7 resistors.
Old 4th November 2012, 03:11 AM   #1975
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Checking in --- good to see expansions on real world build issues discussed in the Vbe and diode drops/I-V et al. One of the reasons I measure so often rather than relying soley on models ---- Sophisticated programs which use known processes and known results of those processes are not in my domain. I measure at the same voltage/current I will be using the part.... and again for same P/N but different brand... no assuumptions. If you don't, the results can be all over the map. We want repeatability for the DIY'er to make and enjoy the fruits of this labor of love.
Old 4th November 2012, 02:30 PM   #1976
Easy experiment take two that are close and parallel them the transistors show the expected 18mV drop but the diodes don't. Again you can probably predict close to what you want with just a VOM.
Old 4th November 2012, 03:40 PM   #1977
diyAudio Member RIP
Somewhere back in ancient times I posted data from a bunch of 4148s, not sure if it was in here. They were off of the same taped batch, not sure of the manufacturer. I taped them to a paper and went down the row touching them only with the Fluke 8062A DVM with the 1mA excitation. The distribution of forward voltages was pretty tight, although a hint of bimodality.
Old 4th November 2012, 06:25 PM   #1978
Anyone know what Ro is?
The 3 online SPICE references don't mention anything at all so this might be only LTspice.
Old 4th November 2012, 06:36 PM   #1979
A quick experiment measuring 1, 2, and 3 matched diodes in parallel gives about 35 Ohms series R so they behave "ideally" only up to 10's of uA.
Old 4th November 2012, 07:29 PM   #1980
hitsware is offline hitsware
http://people.seas.harvard.edu/~jone...jt_models.html
Last edited by hitsware; 4th November 2012 at 07:32 PM. Reason: add link to picture
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2017 diyAudio
