Discrete Opamp Open Design
Old 2nd November 2012, 04:17 PM   #1951
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by scott wurcer View Post
BTW took two strips of 100 4401/4403 from ebay and find most matched better than 1-2mV Vbe.
Sounds like we better get Purchasing to qualify eBay as an approved vendor
Old 2nd November 2012, 06:37 PM   #1952
bear is offline bear
expert in tautology
bear's Avatar
Default some time around 1980 +/- iirc...
dug these out...
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 2nd November 2012, 07:32 PM   #1953
kgrlee is offline kgrlee
I'll help you out this weekend, and get you going (I have not had these problems). I found an old laptop to put LTSPICE on so I won't irritate our lawyers. The OS resistors depend on absolute Vbe a little I'll show you how to compute a close value (you only need the diode function on your handheld VOM).
Hopefully Lord Shiva will look favrably on our efforts.
We grovel at your feet Oh Lord Shiva. Our brother Wurcer is restored to the Light
Was that between 4401s & 4403s or within a strip of 4401s, within a strip of 4403s? ie did the 4401s match the 4403s?
"OS resistors" Was is das? asks dis bum hus unnerstening of 3 or 2LA is wonky
Old 2nd November 2012, 07:44 PM   #1954
aparatusonitus is offline aparatusonitus  Croatia
aparatusonitus's Avatar
Could you please point out that particular ebay seller, thx!
Non mai abbastanza...
Old 2nd November 2012, 08:43 PM   #1955
I uploaded ricardo.txt cos the transistor models should give the same results in other SPICES unless LTspice is doing something other SPICEs aren't.
But what you say implies that using R3, one of the BF862 ltp source degenerating resistors, to adjust offset is suboptimal and there is a better tweak point.
On the FET990, I use the input current mirror resistors which is similar to how its done on many IC OPAs.
Old 2nd November 2012, 09:04 PM   #1956
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Unfortunately, I bought them 2 or 3 yr ago and bagged them up. I meant the matching of 4401 to 4401 etc. Obviously buying strips probably gets devices off of the same wafer near eachother.
EDIT - I don't see any on eBay right now from the same manu, but there are some pretty cheap and of course the pictures don't match the items. One guy picturing strips of 2N2907's.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 2nd November 2012, 09:10 PM   #1957
The 20 Ohm ones, they simply depend on the vbe differences, assuming reasonable thermal connection. This is not hard to do. I have lots of those little TO-92 heatsinks left from the group buy, but just putting the right devices "face to face" and wraping them with a piece of copper tape should be more than enough.
Old 2nd November 2012, 09:32 PM   #1958
grhughes is offline grhughes  United States
grhughes's Avatar
Scott: Are you going to look at cascoding sinks and sources to improve CMRR as R. Marsh suggests? Thanks Ray
" Polarities are seldom aware of their polarness." Prospero
Old 2nd November 2012, 09:53 PM   #1959
Could you name a manu of yours devices?
Old 2nd November 2012, 10:04 PM   #1960
BINGO! The 20Rs on the Output Stage biasing.
Do we tweak the 20Rs so that with 'no' load (incl. F/B bits so no Iq is lost), there is no voltage between the bases of the 'bias' devices and the output?
But that means another tweak pot for i/p stage offset. Got a recommendation for which one to use?
[edit]Just realised the Output Iq isn't just what's going through the 4R7s but a substantial amount goes through the 'bias' transistors & the 20Rs too. When you say "Adj for 8mA", is that just through the 4R7s or the total through the outputs? [/edit]
.. from another project, I recommend a drop of cyano-acrylate in addition to the Cu strap. Substantial improvement in thermal matching.
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
