Discrete Opamp Open Design
Old 25th October 2012, 10:15 AM   #1891
fas42 is offline fas42  Australia
Banned
Just to show how close one can go to matching the JFET curves, below is a grab from the BF862 datasheet, and LTspice's version thereof with modified parameters. There is still a problem unresolved, because the constant Vgs curves shown have been fudged, LTspice keeps insisting on equal spacing of curves between equal stepped values -- those shown represent other than Vgs of -0.1 through to -0.5. Which means that the curve of drain current as a function of gate source voltage doesn't match the datasheet.
This can be circumvented by adding a behavioural voltage at the gate, but maybe there's some fine tuning elsewhere that can be done ...
Frank
Old 25th October 2012, 01:52 PM   #1892
scott wurcer is online now scott wurcer  United States
scott wurcer's Avatar
This is looking better, but there also still seems to be a kink at the transition. The problem for me was simulating the null of seconds for a simple phase splitter. It always walks down to the kink, where a real device has a sweet spot with a very deep null.
The level 3 model has an ALPHASP parameter that fits the entire curve smoothly with a tanh function which has a continuous derivative.
What did you end up using for lambda and B, and did B start doing something?
You might ask why something as fundamental as lambda is so far off in the extracted model.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 25th October 2012, 02:07 PM   #1893
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
IMO curve fitting as used here is often a sub for an incomplete model. but often necessary and useful.
what model is being used and is it complete?
Old 25th October 2012, 05:48 PM   #1894
grhughes is offline grhughes  United States
grhughes's Avatar
I would like to see the schematic of a simple circuit to match jfets BF862 at the voltage they are gona work most linearly in the circuit. I have one for BJTs. Thanks, Ray
" Polarities are seldom aware of their polarness." Prospero
Old 25th October 2012, 05:50 PM   #1895
grhughes's Avatar
Both p channel and n channel? Thanks, Ray
Old 25th October 2012, 05:53 PM   #1896
qusp is offline qusp  Australia
qusp's Avatar
they dont come in a Pchannel
Old 25th October 2012, 06:17 PM   #1897
grhughes's Avatar
But obviously if I'm gona built a circuit to match jfets then it would be nice to match p channel as well. All I'll probably have to do is reverse voltage polarity??? Thanks, Ray
Old 25th October 2012, 06:39 PM   #1898
grhughes's Avatar
It would be nice to measure pinch off voltage on a p channel jfet. I've just never done it. Thanks, Ray
Old 25th October 2012, 06:49 PM   #1899
rsavas is offline rsavas  Canada
I did a google search on "Testing jfets", lots of information!!
Old 25th October 2012, 07:06 PM   #1900
grhughes's Avatar
Been there! Done that! I'm interested in people who have DONE IT and interested in avoiding the pittfalls and interested in the circuit parameters of the SWOPA that I should be looking for; what optimum voltage, what optimum Idss of the BF862. They are probably all over the map out of a sample of 100. Thanks, Ray
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
