Discrete Opamp Open Design
Old 24th August 2012, 05:33 PM   #171
bear is offline bear
expert in tautology
bear's Avatar
Kindhornman, unless you are capable of "holding court" here, then perhaps it is best to sit back and maybe learn something about the subtleties of IC and discrete opamp engineering, design and analysis? Even if *nothing new* comes forth, there is a lot of information that is likely to flow - stuff that unless you were in an engineering group at one of the companies that make this stuff you and I are not likely to be privy to, ever.
Just a thought.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 24th August 2012, 05:38 PM   #172
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by jneutron View Post
70 volts per mil of physical isolation if it is a hermetically sealed hybrid. I assume they enclosed dry nitrogen during lid one shot weld..
jn
These were in plastic SMD of some sort. I'll try to find them. In fact, now that I think of it I specified them in a client's ten pounds in a five pound product, which, as I realized was their custom, never got completed. Although after making a plethora of errors, the layout guy said Why fix those if we don't know that it works, and another person at the company suggested I do all the troubleshooting of the flawed boards for free
Old 24th August 2012, 05:38 PM   #173
jneutron is offline jneutron  United States
jneutron's Avatar
Originally Posted by bcarso View Post
NXP and Diodes Inc. at one time at least made duals that were two isolated chips plucked from adjacent locations on the wafer, with usually not much by way of guarantees but likely pretty decent matching.
Do they still make the LM 194/294/394?
Is the PMI SSM2210 still being made?
jn
Old 24th August 2012, 05:41 PM   #174
jneutron's Avatar
Ah, thanks.
Encapsulation compound dielectric strength is less than 425 volts per mil, I'd never go over 250 volts/mil. Externally, I'd stay under 25.
jn
Old 24th August 2012, 05:41 PM   #175
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
John;
the second stage is loaded on very different resistances: one to ground, another bootstrapped. One output device works with common source, another with common drain. As the result, highly modulated current through output devices and awful distortions, starting from the 2'nd order. Extremely poor thermal stability, both of output voltage and idle current.
The Devil is not so terrible as his math model is!
Old 24th August 2012, 05:41 PM   #176
diyAudio Member RIP
Originally Posted by bear View Post
Then the next question - for those of us who must follow the opera by reading the libretto - references, papers and texts to stare at blankly in the vain hope of discovering only some of these complexities...
this is one I discovered in the first edition years back... I don't pretend to have digested it all by any means:
Bipolar and MOS Analog Integrated Circuit Design (Wiley Classics Library)
By: Alan B. Grebene
_-_-
PS. when I first saw this book, I thought to myself - "myself, how the heck did this guy learn all of this, when all the other texts I have seen don't even scratch this surface at all??" (ie. where are they keeping the real information hidden? Do you have to reinvent the wheel for yourself?)
Both the "first edition" which actually had a different title and the one you mention are great books. Why not seen elsewhere? Well, some of the disclosed things were proprietary. IC manufacturers have to make money and if possible retain a competitive edge.
Old 24th August 2012, 05:45 PM   #177
john curl is offline john curl  United States
john curl's Avatar
Really Wavebourn, are you sure?
"Condemnation without Examination is Prejudice"
Old 24th August 2012, 05:48 PM   #178
diyAudio Member RIP
Ah, thanks.
jn
One such part: DMMT3906W, in SOT-363: http://www.diodes.com/datasheets/ds30312.pdf
I see there are some matching specs.
Brad
Old 24th August 2012, 05:48 PM   #179
john curl's Avatar
Another example of hi end design:
Old 24th August 2012, 05:51 PM   #180
expert in tautology
bear's Avatar
Brad, sorry I should have said "that I had not seen elsewhere...". Doesn't mean that this stuff was not out there, just that sitting in relative isolation, I had not found it via various pseudo random efforts to locate this sort of information - this was before the internet as we know it today... that meant trips to various university libraries and bookstores - many of the texts were even back then in the >$100 range, which was daunting. I persuaded someone to make me a photocopy of Grebene, because I couldn't swing the bux for even a used copy... whaaaaa!
_-_-bear
_-_-bear
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 07:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 04:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 01:52 PM
Copyright ©1999-2017 diyAudio
