Discrete Opamp Open Design
Old 14th October 2012, 05:49 PM   #1671
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by rsavas View Post
Top assembly drawing.
Took me equivalent of < one working day to get this far, so it ain't hard to duplicate. Suggest to put some copyright's notices on the material, if we want to protect the information? I have not seen any copyright notices on material on this site!
Seems that all the jfet mfg's can agree on a standard pin out, in SOT23, so can substitute parts quiet easilly.
Looks like a nice job. I love how large the SOT-23 packages appear compared to the complementary duals
Old 14th October 2012, 06:43 PM   #1672
grhughes is offline grhughes  United States
grhughes's Avatar
Thanks Brad!
" Polarities are seldom aware of their polarness." Prospero
Old 14th October 2012, 08:46 PM   #1673
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by donpetru View Post
I have attached below an audio preamplifier that can be the basis for achieving an operational amplifier with discrete components.
All inputs are appriciated, but with all due respect this is pretty far from a broadly applicable circuit. With 1K output resistance, split feedback, and here set up for phono there would be major changes needed.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 14th October 2012, 09:14 PM   #1674
Originally Posted by qusp View Post
$40-50USD for standard values in 0.01%; for what you will get in exactly the custom value you want from Texas components in 0.02% for ~$10-12....
I was thinking more of pennies for the resistors.
Old 14th October 2012, 09:30 PM   #1675
Here is a first shot at a blow by blow description of my op-amp idea. No guarantee that it is clear to everyone so important clarifications can be added.
Old 14th October 2012, 10:09 PM   #1676
jcx is offline jcx  United States
splitting the Ccomp, bootstrapping the middle to the driver output gives 30 dB more loop gain to 20 KHz; costs < 10 degrees phase margin
heck it even looks like flat loop gain to 10 kHz
from the below Ltspice sim, simple Middlebrook loop gain V souce in series with feedback divider
split Comp, doubled pF, added 500 Ohm to Q15 emitter
green trace: original single pole loop gain;
yellow: split, bootstrapped Ccomp 2-pole comp
Originally Posted by fas42 View Post
To keep the ball rolling, here's a quickie knock up of the schematic from #1568 for those who are averse to fiddling with the versions already posted. Appears to be OK, haven't checked everything, I'm sure people will point to any problems ...
The PSRR looks much, much better of course. One thing though, can't push the output standing current up to 8mA easily for some reason ...
Frank
Old 14th October 2012, 11:17 PM   #1677
This is good, we tend not to use these techniques because they can effect fine scale settling. For audio this might not matter.
Old 14th October 2012, 11:19 PM   #1678
diyAudio Member RIP
Default statistics on 19 BF862
Finally set up to screen some today off a strip and got through 19 pieces. The tempcos are all fairly small and the measurements didn't take long to settle. The bench ambient was about 75 F.
Vds was fixed at 4.00V except for the drop across a current sampling resistor in the drain of 10.0 ohms. 200 ohms was in series with the gate to prevent RF oscillations. Idss was measured, then the reverse bias on the gate to bring the current down to 100uA.
Mean value of Idss: 15.693mA. Standard deviation 1.567mA.
Mean Vgs for 100uA Id: -634.3mV. Standard deviation 43.9mV.
I also looked at Id with the gate floating (actually tied to the source through the 200 ohms and 330pF). This value corresponds to the operating point where the drain-gate leakage current is the same magnitude as the forward gate-source current. It ranged from a high of 25.2mA to a low of 17.8mA.
So, for differential applications matching is necessary. The good news is that otherwise the temperature coefficients are small.
Old 14th October 2012, 11:23 PM   #1679
diyAudio Member RIP
I've been looking at settling in sim lately as a matter of course. I can't easily simulate thermals, which are there if you look hard enough, but it's interesting to see how close intuition is to what sims say.
I wonder what the 990-style compensation does to settling behavior?
Old 14th October 2012, 11:24 PM   #1680
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I would say, for audio wider flat loop gain matters more, and +30 dB on 20 kHz is a huge advantage.
The Devil is not so terrible as his math model is!
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 07:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 04:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 01:52 PM
Copyright ©1999-2017 diyAudio
