Discrete Opamp Open Design
Old 10th October 2012, 10:25 PM   #1591
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by Waly View Post
Careful. BF545 has a minimum pinch voltage of -0.4V. If by chance you run into the worst case combination of BF862 and BF545, the BF862 may not saturate (but stay in the linear region).
Better find a n jfet with higher pinch voltage, like this. Only 25V Vds but dual, and -2V minimum pinch voltage.
Good advice, the data sheet is a little unclear but from my read the BF545C is fine. That last line of Vp at 1uA looks like it covers all the grades, not sure why it's there.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 10th October 2012, 10:27 PM   #1592
fas42 is offline fas42  Australia
Banned
Hmmm ... in my sim I have very good agreement on the +ve PSRR figures, but the -ve PSRR is dramatically superior at lower frequencies for stinius. I do note that the -ve PSRR is highly variable, depending strongly on the choice of BJTs, so I'll try replicating stinius's selections ...
Frank
Old 10th October 2012, 10:44 PM   #1593
Frank
AC or DC? You can scope out the DC component by doing a DC sweep and poking around.
Old 10th October 2012, 10:55 PM   #1594
Banned
AC. I also note that PSRR is highly dependent on the output DC operating point; if I trim the circuit to minimise DC offset it actually worsens PSRR behaviour - I'm not sure whether this is a sim artifact so far, and I don't have anywhere near enough knowledge about amplifier tolopogies to understand behaviours in an intuitive way ...
Frank
Old 10th October 2012, 11:29 PM   #1595
Frank
In the end this will depend on build and we are smart enough to tweak it if need be.
Old 11th October 2012, 03:21 AM   #1596
fitzfish is offline fitzfish  United States
This thread has highlighted some very interesting small JFET dual parts. Thanks Scott, Brad, and everybody else who has made parts suggestions along the way.
Dave
Old 11th October 2012, 06:51 AM   #1597
Banned
Mystery solved - he's added two more cascodes, Q7 and Q8. Using J111s there I'm now able to get 125dB -ve PSRR with one BJT combo, still 100dB at 20kHz ...
Have to say the sim distortion figures are truly excellent, even at gains of 100 ...
Frank
Old 11th October 2012, 01:49 PM   #1598
Just noticed this morning another AM radio FET but dual. Someone should evaluate the matching and audio frequency noise. This could be another gem like the BF862. But the user will be punished by an even smaller package.
Old 11th October 2012, 01:54 PM   #1599
EUVL is offline EUVL  Europe
If you refer to the PMBFJ620, then it has much higher noise and much lower Yfs than the BF862.
Idss is also way too high.
The package is a small problem. We have soldered even 0.5mm pitch 6-pin.
It is humanly possible, even by hand.
Or you are talking about another device ?
Patrick
xen-audio.com
Old 11th October 2012, 02:00 PM   #1600
Patrick
Yes, then it should stay in cascode duty. I do like the contrast between the parts we are discussing and the usual almost obsolete ones. I think one of the npn/pnp duals had 5 million and 3 million "ready to ship" at the first two distributors.
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2017 diyAudio
