Discrete Opamp Open Design
Old 5th October 2012, 01:47 AM   #1531
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by fas42 View Post
Just tried something else in my version of SW-OPA, looking at PSRR. At 20kHz, only a bit over 15dB on the -ve supply, 30dB on the +ve when working at a gain of 20. So an extremely well regulated supply will be necessary for the circuit as is ...
Frank
Not to knee-jerk defend, but are you measuring this based on your closed-loop gain of 101?
Old 5th October 2012, 01:55 AM   #1532
qusp is offline qusp  Australia
qusp's Avatar
anyway isnt it time to put the new Jung shunt superreg to the test? anyone built that yet?
Old 5th October 2012, 02:17 AM   #1533
fas42 is offline fas42  Australia
Banned
Feedback resistors of 2k, 40K. Tried also 2k, 10k, so gain of 6, that improved performance by about 10dB ...
Frank
Old 5th October 2012, 02:53 AM   #1534
diyAudio Member RIP
Frank
Sorry, my overlook.
Old 5th October 2012, 04:35 AM   #1535
Banned
And of further interest, a member PM'ed me about a breadboard he's already knocked up, and his PSRR figures, measured at lower frequencies, correlate beautifully with what the sim predicts ...
Frank
Old 5th October 2012, 05:22 AM   #1536
fitzfish is offline fitzfish  United States
Frank,
dadod's version sims at about ~-25db at 20KHz on the negative side with your 20K/2K feedback values. Switching to K170/J74 models for the front end @ 7mA, everything else otherwise the same, brought it up around ~-31db at 20KHz. Low frequency is about -89db for the LSK389/J109 with the knee at about 65Hz. The K170/J74 was in the -96db range with the knee around 70Hz. High side PSRR is better.
All based on the LTSpice sim of course… Anybody else get similar numbers from it? It would be nice to know it works the same in multiple locations, even if just in the sim at this point.
Dave
Old 5th October 2012, 12:33 PM   #1537
BFNY is offline BFNY  United States
This circuit is shown here, and discussed close to the end of the Audio Xpress interview with Walt Jung
WaltsBlog
Probably off topic here, but worth a new thread in the right place...
Old 5th October 2012, 02:21 PM   #1538
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Frank
PSRR is something to look at and there could be some tweaks. I would expect non-cascoded inputs to be fairly sensitive to source impedance mis-match. Welcome to the design process.
EDIT- OK we need to track down the discrepancy, the very first circuit (all N flavor FET's but input cascoded) shows me flat -100dB RTI on both supplies out to 20K.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 5th October 2012, 03:43 PM   #1539
diyAudio Member RIP
General appeal: could people please reference a post # when referring to a design? It would burden things unduly to attach the schematic each time, but at least we can use the number and go back and confirm what we're talking about.
Old 5th October 2012, 05:04 PM   #1540
stinius is offline stinius
PSRR
This is what I'm getting when simulating Scott's BF862 circuit with the buffer.
I have also attached the schematic I'm using, showing how I do the PSRR simulation. Maybe I'm doing it wrong?
Stein
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2017 diyAudio
