Discrete Opamp Open Design
Old 24th August 2012, 01:09 AM   #141
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by dirkwright View Post
He says right in the article that a version of it was first used in the LH0002 buffer, which I assume was a chip.
I have about 20 of them on PCBs. Do they have any ebay value?
I used discrete version of diamond buffer in phaser pedal for keyboard, in 1970'th. It was all discrete, with LDRs around a light bulb, using pnp+npn "concertinas" for APFs. Such a way I kept almost zero level shift.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 24th August 2012, 01:14 AM   #142
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by RNMarsh View Post
can you tell us in which ways this is different from an IC packaged circuit? What parameters can be bettered with discrete (besides output current)? Thx RNM
No claims made other than output current, bias, etc. diy'ers feel good about doing it themselves i.e. fun.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 24th August 2012, 01:23 AM   #143
hitsware is offline hitsware
The H in LH was for hybrid (IIRC)
Old 24th August 2012, 01:23 AM   #144
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Please explain in more detail the rising thd with frequency cause. Thx - RNM
Old 24th August 2012, 04:13 AM   #145
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by bear View Post
Yes, this is the usual method of bringing the opposing collectors of the input to the rail... Was Walt Jung first or?? But, the variation of bringing them to the output stage, between the emitter resistor and the output device is an improvement. Incremental. But incremental counts?
I believe HP used the diamond buffer pretty early on, according to Rich May, who then did some discrete buffers for a crossover he did at Harman for Greg Timbers. But who knows --- as Scott pointed out in connection with Jensen's input inductor(s), these things often are proprietary within a company for a while, and thus the USPTO doesn't necessarily know about them when they review claims.
Rich also bootstrapped the collectors of the input devices for his circuit, but did so with big caps and resistors to the rail, rather than running them from the output device emitters. This has advantages (smaller Ccb to begin with), but requires some bulky caps.
Both bootstrapping approaches help reduce the effects of the voltage-variable collector-base capacitances, as well as Early effects on beta and Vbe. The capacitance variation is a distortion mechanism that is proportional to the source impedance and the frequency. Another advantage is reduction in dissipation shifts with voltage.
Old 24th August 2012, 05:45 AM   #146
Bonsai is offline Bonsai  Europe
Scott, I thought the challenge was for 8 transistors? ;-)
Old 24th August 2012, 11:56 AM   #147
elektroj is offline elektroj  Europe
What about moving biasing of output devices to the 2nd gain stage?
Old 24th August 2012, 12:50 PM   #148
john curl is offline john curl  United States
john curl's Avatar
Let me offer an example of a simple, elegant, balanced circuit that can be made into the highest quality amplifier, preamplifier, or whatever, with a minimum number of parts.
This is NOT my circuit, and it is at least 40 years old, but Constellation makes world class amps with it, today. I give the credit to Bascom King, but it might go back earlier, I don't know.
"Condemnation without Examination is Prejudice"
Old 24th August 2012, 01:23 PM   #149
Hentai is offline Hentai  Japan
The biggest advantage that i see in discrete opamps would be higher power supply voltage capability and thus higher output voltage swing.
Old 24th August 2012, 01:25 PM   #150
I thought P Channel JFET's were out for this exercise. I can also see why you worry about clean supplies.
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
