Discrete Opamp Open Design
Old 23rd August 2012, 11:22 PM   #131
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Default All-in-One
Originally Posted by bcarso View Post
By exploiting the use of floating power supplies, to which EUVL has gotten me momentarily addicted after I started looking at his IV threads, and with RM's allowance for cascodes and current sources not counting, I have a crazy design for the opamp that uses six transistors. But two to four floating voltage sources (one to three of which could be primary batteries as there is virtually no current), a very asymmetrical-looking input stage... If all one needs is an inverting input the thing gets much simpler and the floating V source that actually supplies real current goes away.
When I have convinced myself I understand it I'll present it. It does use the buffer I showed, and counts that as four devices (the two current sources being exempt).
Of course I'm not doing this to meet the eight transistor limit, but I'm amused that it may be possible. I don't believe it will sound better on account of the lower number.
[Make the power supply the amplifier and visa versa. ]
Old 23rd August 2012, 11:48 PM   #132
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
Which brings up the question: is this to be an op-amp in the sense of something critically dependent on power supplies to be almost as good as it is?
And, must it have two inputs and one output, two power supplies?
Thanks,
Chris
Old 23rd August 2012, 11:53 PM   #133
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Actually he wants a headphone amp. I have no idea why a headphone amp has to use opamps. I use in mine MOSFETs and BJTs in power supply, and SiC JFETs and vacuum tubes in the amp. It does not resemble any opamp. Well, it has balanced inputs, but it is transformer-balanced, no DC gain at all.
However, I have to admit, I am a zero in marketing...
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 24th August 2012, 12:13 AM   #134
hitsware is offline hitsware
It's because you took the engine off your bicycle .....
Old 24th August 2012, 12:29 AM   #135
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
First off this is for fun and exchanging some ideas. I make no claim to inventing anything here it has all been somewhere before.
Classic op-amps input gm, Vas, and output buffer all end up relying on a linear input voltage to current stage (gm) feeding current to a high impedance node whose voltage is buffered to create a low output impedance. There are lots of embellishments around to increase the DC gain but the AC performance is usually limited by the linearity of the gm, the linearity of the gain node impedance (at AC frequencies the compensation capacitance plus any parasitics), and both the current needed to drive the output buffer and the voltage error across the output buffer. The last is problematic in that it (usually the crossover distortion) is differentiated before it can be expressed as an input current error, hence the rapid increase as frequency increases.
Before I go on I would like to say that a one size fits all op-amp is simply an unnecessary restriction. A simple enough signal path can give the user a couple of foolproof component substitutions that can optimize it for each application.
This being said I want to present a very ordinary signal path with a couple of additions to preserve simplicity and linearity. This circuit is not new but there are some differences to previous versions that I have seen (I donít see everything posted). The signal path on the non-inverting side has been arranged more like a current mirror and on the other a folded cascade. The cascodes on the gain stage have their base current recaptured to keep the collector impedance very high and eliminate non-linear capacitive currents. The bootstrapped triple darling presents a very light load to the gain node and can be independently customized to easily drive low impedances. Though as I have previously stated there is no reason for every op-amp in your signal path to drive something like 50 Ohms.
The circuit here is just an outline and the devices are place holders but even with these fairly ordinary devices Aol is > 100k and more importantly the gain at 20K is 75dB. J1 and J2ís currents are set for bias and to set up the lower half of the input stage to also recapture the base current of the cascodes. Originally I had planned on a completely symmetric circuit with PFETís. That is a fairly easy exercise for the reader.
I would like some suggestions for transistors, as far as I can tell I can get better than -100dB distortions at 20K, etc. with nothing more than this. As I said the degeneration resistors and comp cap would need to be changed for gain of one operation.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 24th August 2012, 12:37 AM   #136
RNMarsh's Avatar
Not really. The opamp apps today needs to drive more than just other amp/hardware inputs. -RNM
Old 24th August 2012, 12:42 AM   #137
bear is offline bear
expert in tautology
bear's Avatar
Originally Posted by elektroj View Post
I think this particular one (LEDs in current sources) is Walt Jung's creation:
http://waltjung.org/PDFs/WTnT_Op_Amp_Audio_2.pdf
Yes, this is the usual method of bringing the opposing collectors of the input to the rail... Was Walt Jung first or?? But, the variation of bringing them to the output stage, between the emitter resistor and the output device is an improvement. Incremental. But incremental counts?
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 24th August 2012, 12:46 AM   #138
RNMarsh's Avatar
Default how is it different from IC?
can you tell us in which ways this is different from an IC packaged circuit? What parameters can be bettered with discrete (besides output current)? Thx RNM
Old 24th August 2012, 12:56 AM   #139
Wavebourn's Avatar
Not really. They don't need to be opamps, no matter what they drive.
I have to admit, I like Scott's exercise. Quite elegant.
Old 24th August 2012, 01:00 AM   #140
dirkwright is offline dirkwright  United States
dirkwright's Avatar
He says right in the article that a version of it was first used in the LH0002 buffer, which I assume was a chip.
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
