Discrete Opamp Open Design
Old 20th September 2012, 11:20 PM   #1101
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
George, with loudspeakers that is another story. I use the Klippel and Praxis since they came out. I can show you that a very well designed speaker has distortion under the audible threshold. Bill Waslo and i designed a distortion isolation test that put the original signal in one ear with headphones and the distortion residuum in the other. With well designed speakers i could hear NOTHING in the distortion channel because of masking.
Switching out the music on the undistorted channel i could hear something. Audio magazine even put out a CD with my measurements. An altogether harder problem is dynamic range and bandwidth, in speaker that is. Using the Klippel i got that distortion down by 10dB the last 10 years.
Old 20th September 2012, 11:24 PM   #1102
Here is the distortion measured at 1 Pascal on the midrange of my private speaker.
Between 200Hz and 5KHz it is under 0.1%, better then many tube amps.
Old 20th September 2012, 11:27 PM   #1103
1 Pa ( Pascal ) is 94dB sound preasure.
Old 20th September 2012, 11:29 PM   #1104
The distortion isolation test :Distortion Isolation in the Time Domain
Old 20th September 2012, 11:37 PM   #1105
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
In the context of designing an opamp circuit -- which tests will best seperate them and determine weaknesses and in the end, which design is the better one? Or which combinations of tests will determine which is the better circuit? This knowledge can drive the design. Thx - RNm
Old 20th September 2012, 11:48 PM   #1106
Here are the dynamic measurements i did on an INA i constructed with 2 AD797 and 1 LT1648 for MC cartridge head amp purpose.
Watch the scale, the resolution limit is at -150dB. This is done by gain ranging two 24Bit AD/DA converters. The measurement are pretty astounding and the sound i got was very good. I can do better though subjectively with designs that measure still very good but not as well.
Old 20th September 2012, 11:49 PM   #1107
Here is one more. I even called it "Gold standard" because it measured so well.
Old 21st September 2012, 12:15 AM   #1108
fas42 is offline fas42  Australia
Banned
My personal feeling is that it will be the one that has the best rejection of noise and interference by the very nature of the topology. Obviously PSRR is a prime culprit to be investigated, but what about throughout the rest of the circuit: if the circuit is poorly executed by a DIY'er and can easily pick up stray signals, couple with extraneous influences, then how many weak spots in this, theoretical design, sense, occur through the circuit at the various junctions of the parts?
Frank
Old 21st September 2012, 12:19 AM   #1109
gpapag is offline gpapag  Greece
gpapag's Avatar
Hi Joachim
What does this measurement show?
And I wasn't meaning loudspeaker testing.
Thanks for the link Distortion Isolation in the Time Domain
George
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 21st September 2012, 12:20 AM   #1110
RNMarsh's Avatar
very nice results --- Do you have data on other speakers/drivers that are as good? Such as, one of my favorites I drag out every so often -- The New Quad electrostatic speakers? I understand they re very low distortion full range speakers. My reference speakers for very low distortion and very flat response.
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2017 diyAudio
