Discrete Opamp Open Design
Old 20th September 2012, 11:55 AM   #1071
fas42 is offline fas42  Australia
Banned
Originally Posted by RNMarsh View Post
The harmonics of a single tone produces some 'grass' on the FFT plot. Say .01% thd worth; Can't be heard. More simultanious tones, more grass growning and IM grass, too. After 20,000 tones have been applied, that .01% THD of each of thousands of tones adds up to enough to reach audible levels. The audible effect is an equivalent increase in the background noise level. Which is described as masking details or changing character of the sound depending on music freq content played. This might be why we need Really low thd numbers on a single tone test.... to prevent the accumulated harmonics of many simultaneous tones from reaching an audible threshold. -Thx RNM
Okay, let's go back to the original premise: "accumulated harmonics of many simultaneous tones from reaching an audible threshold". Let's try for infinity (and beyond!): what happens when the number of tones increases a magnitude, for each trial: by Richard's assertion, at each tenfold increase in number of tones the overall level of distortion will increase by at least some amount. So the limit as the number of tones approaches infinity is that the signal becomes completely distortion, nothing but. So an input signal that is composed of a number of tones approaching infinity is also output totally as distortion. Hmmm, where's the hole here ... ?
Frank
Old 20th September 2012, 12:08 PM   #1072
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by bcarso View Post
One thing I noticed about Bob's non-global-feedback MM preamp: it assumes the cartridge is connected differentially. This I suspect in large part accounts for the reasonable distortion numbers, as even harmonics will nearly cancel.
This is a blunder, I've had common mode effects on the brain lately; MM single-sided operation will be fine, especially given the cascoding, as long as the other side is grounded through a lot less than 100k. Thanks SG for pointing this out.
Old 20th September 2012, 12:59 PM   #1073
Banned
Originally Posted by janneman View Post
Let me try:
You have 20k amplifiers each having a transfer characteristic 'A', each being fed a signal S1....S20k. Each amp output is thus A*S1....A*S20k. After the perfect summer you have A*(S1+S2+...S20k).
Now take a single 'A' amp and feed it (S1+S2...S20k). Output will be A*(S1+S2...S20k).
Looks like a match to me. Of course, we could have skipped all of this by just invoking the superposition principle
jan
There's a simple counter example to this scenario: take an amplifier with extreme even harmonic distortion, positive excursions severely differ from negative excursions in wave shape. Take 2 perfect sine waves of matching frequency and amplitude, but opposite phase as input: output from summing device is the difference between the positive and negative wave shapes; but that from the combined signals fed into single amplifier will be a null.
Frank
Old 20th September 2012, 01:53 PM   #1074
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Frank
Yes if you sum two perfect sinewaves that are 180 degr out of phase you get zero. Send that through an amp and the output is still zero.
Not sure what that proves?
jan.
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 20th September 2012, 01:58 PM   #1075
jan.didden's Avatar
In the other case, say your amp has a transfer function of 1*Vi + 0.5*Vi^2 (lots of 2nd harmonics as you postulated).
The 'pos' sine wave V gets an output of 1*V + 0.5*V^2.
The other is 180 degr out of phase so that amp gets an input of -V and the output is 1*-V + 0.5*-V^2. Add that after the two amps and again you get zero.
You'll have a hard time to prove the superposition principle wrong.
jan
Old 20th September 2012, 02:41 PM   #1076
Banned
Or is that, 1*-V + 0.5*(-V)^2? That does not sum to zero ...
Frank
Old 20th September 2012, 02:50 PM   #1077
jan.didden's Avatar
Frank
Hmmm...
Old 20th September 2012, 03:33 PM   #1078
Waly is offline Waly
Hmmm...
The superposition principle (it is actually a theorem) holds for linear systems only.
Old 20th September 2012, 03:49 PM   #1079
jan.didden's Avatar
Yes I just found that out too. I thought it was valid for continuous systems as opposed to discrete time systems.
Another learning moment! Life is good
Edit: another give-away that I was wrong was, that if I was right, we wouldn't have the cancellation of harmonics in push-pull systems. Silly me.
jan
Old 20th September 2012, 06:09 PM   #1080
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Frank
I'm unconvinced that amp distortion level remain at same low level.... more tones begets more harmonics from amp nonlinearities. But, an interesting thought.
Discrete Opamp Open DesignHide this!Advertise here!
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 07:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 04:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 01:52 PM
Copyright ©1999-2017 diyAudio
