Remote control won't shut up - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 21st August 2012, 10:53 PM   #1
Default Remote control won't shut up
I've gotten my Hafler Iris remote control working again, just too well. It uses what I assume is capacitive sensing to start and stop transmitting the positions of the volume and balance pots. When I touch either knob it correctly changes the volume of my preamp to what the remote's knobs are set to. It just doesn't quit transmitting when I let go. Sometimes it stops after 10-30 seconds. Sometimes I have to take out a battery to stop it.
Now some background. It was tending this way a few years ago, especially during the summer. Finally it went on by itself, ran the batteries down and made them leak. I cleaned up the electrolyte and replaced a corroded IR LED. The battery pack wires had corroded and broke while I was handling it. Things got more complicated when I wired the new battery pack backwards and blew a power diode. I've replaced the diode with one that I guess is equivalent. I guess that the IR LED is equivalent too. I have no idea if any other component is damaged. The other IR LED (there are 2) has a little discoloration on the leads inside the package, but it may be working. Could the IR LEDs be part of the capacitive sensing circuit? That's hard to believe.
There's nothing obvious to adjust the capacitive sensitivity. I now see a spot or two of dried electrolyte that I missed. I'll try to clean it up with some distilled water on a flux brush and dry it quickly. Any other suggestions to troubleshoot this problem? Any other forums that might have experience with this kind of circuit? I've asked around about a schematic, but I'm not sure that it would help me and nobody seems to have one.
Old 22nd August 2012, 07:35 AM   #2
Mooly's Avatar
It would help to see a picture of the remote as I've never seen one of these.
Are you sure it's not just a "membrane" overlay on the handset. (These were common on many consumer remotes and front panels of equipment) and always gave trouble after a while. Basically two conductive sheets that rely on pressure to make the connection and they often became more conducting than not.
Membrane keypads,
http://www.bing.com/images/search?q=...FD51B&first=36
Old 22nd August 2012, 05:08 PM   #3
Red face Wish I could show a picture
Sorry, but I can't find the mechanism for creating an album described in the FAQ, so no photos. I'll just have to tell you that this circuit in no way uses a membrane switch. This has to be a capacitance sensing circuit. The shafts and cases of the volume and balance pots are connected through RC circuits to the inputs of a LM8030N Op-amp transconductance amplifier. I can't figure out any more than that.
Old 22nd August 2012, 05:15 PM   #4
kevinkr's Avatar
Click on "Advanced" if that option is showing and then "Manage Attachments" then go to "Upload File from your Computer" click browse and navigate to where the picture is that you want to post and click "OK." Remember to click "Upload" once you have selected all of the pictures you want to upload. Try to keep pictures in the 800 x 600 range to avoid too large files.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 22nd August 2012, 05:36 PM   #5
Default Some photos
Wow. That's not what the FAQ says. Firstly, there's an "Insert Image" icon in the "Reply to Thread" editor. That requires a URL, so I went looking for creating an album. The directions in the FAQ talk about a "Pictures and Albums" link in the CP. Dead end. Anyway....
Old 22nd August 2012, 05:58 PM   #6
Mooly's Avatar
Thanks for the pics... now that is one oddball remote for sure. So we have push buttons for certain functions and true analogue pots for the volume and balance.
I don't think there is any capacitive sensing going on as it seems to detect where the pots are (resistance value) and code that in some way.
Do you position the pots first and then press a "send" button or is it working all the time and you just move the pot and the one on the amp follows suit ? Thats an important question because it eliminate a button and the possibilty of a problem in that area.
Without seeing and getting a feel for this I don't know, but would suggest basic handset repair tatics. I used to see hundreds of remotes in the course of the day job and a favourite tatic was to totally wash the PCB with foam cleaner and a brush and then rinse and dry. As long as there are no "open" parts there isn't a problem but I see you have all those switches. To wet them without knowing their construction could cause a problem. You could do everything else though.
You need to pin this down a little... I'm intrigued
Old 22nd August 2012, 07:08 PM   #7
Default Oops, washing right now
It's not necessary to move the pots to make the remote xmit; just touch the metal knob or the bare shaft or the potentiometer case. Even if I touch any of these with a piece of wire, it xmits. There is definitely a trace from the lock-nut to a cap and then to the op-amp. I am convinced that this is a capacitance sensing circuit.
Thanks for the suggestions. I'm sorry to learn that you don't suggest cleaning the board because of the open switches (& pots). I have already done a careful rinsing of visible corrosion spots with distilled water on a flux brush. I don't think that any got into the open components. Now I'm going over it more aggressively with reagent-grade isopropanol and blowing off the liquid with compressed air. I hope that if any rosin flux gets carried onto contacts I will be able to clean them with Caig Cramolin R-2 spray.
Old 22nd August 2012, 07:34 PM   #8
Mooly's Avatar
Just being careful with the recommends on washing. I used to wash whole TV 'chassis (and we're talking very high voltage here) with no problems at all as long as they were totally dried afterwards. Just don't want you to run into trouble with a part that may take eons to dry... and any moisture really is a problem when voltage is applied as it causes electrolysis.
I'm really intrigued though as I say.
So is that the way it is meant to work by design, that you just touch the metal knob and it transmits ? If so then capacitive touch sounds likely.
So if you have the unit on say a table and touch the volume pot it transmits, but then continues to do so as your finger is removed when it should have stopped ?
Old 22nd August 2012, 08:19 PM   #9
Default You got it.
So if you have the unit on say a table and touch the volume pot it transmits, but then continues to do so as your finger is removed when it should have stopped?
Yes, that's it exactly. It's not being consistent about it either. Today it was working well. That may be because it was out of it's case and without the knobs or maybe because the humidity is low. (The original problem was spontaneous xmitting on very humid days, which eventually caused the batteries to leak.)
Thanks for the warning about electrolysis. I expect the 100% isopropanol to carry off any moisture and I'm using 50 psi (3.5 bar) air to blow everything away. I'm following the tutorial given by Warren Young in How to Clean Circuit Boards. The board has plenty of time to dry while I fix the battery pack leads which have broken off again due to my handling.
To get a more detailed understanding of how this volume control system works, see the Stereophile article, Hafler Iris preamplifier | Stereophile.com , page 2. There's a relevant anecdote near the end of the article too.
Old 23rd August 2012, 06:33 AM   #10
Mooly's Avatar
Thanks for the Hafler link, interesting stuff.
I think you will have to see how the cleaning goes. I would carefully remove the IC's too and wash those particularly around the pins (be carefull of static precautions on any relevant devices) and use a soft brush to get under the IC sockets.
You mention high humidity. Is the board laquered and become sticky. If so that could be a problem and may require more aggressive cleaning perhaps with pure ISO.
Remote control Passive Volume Control with Display ua100k Swap Meet 2 31st May 2011 03:01 PM
Remote volume control for existing remote? theAnonymous1 Parts 7 6th August 2007 08:22 AM
The remote control paratactic volume control audio-gd Solid State 33 7th June 2007 11:16 PM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 11:12 AM
Copyright 1999-2017 diyAudio
