Jfet Line preamp, to cascode or not.
Old 19th August 2012, 07:25 AM   #1
velvetsunrise is offline velvetsunrise  United Kingdom
Default Jfet Line preamp, to cascode or not.
Hi
I am considering building this line amp, but unsure weather there would be any improvements to be had by cascodeing the input Jfets with either BJT, or higher VP fets.
Any comments welcome.
Thanks.
Old 21st August 2012, 04:18 AM   #2
rcw666 is offline rcw666
What I was wondering was why you propose to use it at all let alone replete with cascodes.
rcw
Old 21st August 2012, 05:28 AM   #3
Well i know a similar topology has been used open loop as a phono amp. It occoured to me it may make a reasonable line amp either with the gain lowered by current feedback as shown or even open loop with say a diamond buffer in place of the output emitter followers.
Do you have a specific reason for disliking the circuit?
Old 21st August 2012, 05:33 AM   #4
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Have you build it ?
Old 21st August 2012, 05:39 AM   #5
Hello Joachim
No, not yet.
But i probably will
Old 21st August 2012, 05:47 AM   #6
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
cascode will improve distortion and power supply rejection. best done with bipolar for highest cmr. -RNM
Old 21st August 2012, 05:50 AM   #7
It should work. I have ideas to improve it but you should build a prototype first.
Old 21st August 2012, 05:58 AM   #8
Thanks, i will add some BJT cascodes to the input fets, biased with LED strings, and give it a try.
Old 21st August 2012, 08:18 AM   #9
It is just that I have never been convinced about the merits of symmetrical designs for audio, or the use of cascodes in them, it seems to me to be a great deal of needles complexity for very dubious benefits.
Symmetry certainly has esthetic appeal but that is all the merit I can see in it.
rcw
Old 21st August 2012, 12:21 PM   #10
bear is offline bear
expert in tautology
bear's Avatar
I'd think about the F5 amp, this is somewhat akin...
I'd want to lose the cap coupled output myself.
perhaps a servo or other means to stabilize the DC point.
Also, not sure I want diodes for the biasing string... maybe, but maybe not... people do seem to use them a lot...
Mosfets for the output?
What is the purpose of the current mirror (just asking)?
Also the input pot is drawn backwards...
_-_-bear
PS. did you simulate it yet and see what it specs at?
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Jfet Line preamp, to cascode or not.Hide this!Advertise here!
Complementary JFET-JFET cascode input, BJT VAS-Drivers, Lateral Output Neutrality Solid State 61 2nd October 2015 07:35 AM
jfet SRPP cascode Stee Solid State 0 13th March 2010 12:50 PM
Jfet/Mosfet cascode with OPT Fuling Pass Labs 10 3rd December 2007 06:53 PM
Did I get this JFET Cascode right? KP11520 Digital Source 28 24th September 2007 05:16 PM
Krazy PSU for JFET cascode BOSOZ jh6you Pass Labs 24 14th February 2006 04:00 PM
Copyright ©1999-2017 diyAudio
