Balanced Signal over 500 Metres! - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 19th August 2012, 04:28 AM   #21
Thanks everyone again for the various ideas. Obtaining AC power at the main gate is not an issue. The Microphone already in their possession is attached.
Sam
Old 19th August 2012, 06:59 AM   #22
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Meaning there is or isn't power.....?
If not - 2 ( or more ) pair cable - feed 24V dc on one pair, and then proper decoupling, regulation and filtering before feeding a decent balanced mic preamp. OR - find a good circuit for phantom powering, but preamp and driver seems better solution....
600m mic cable and no preamp - forget it...
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 19th August 2012, 08:56 AM   #23
pinkmouse's Avatar
Chaps you're over-complicating the issue. A standard balanced mic will work fine over 500m. I've run much longer. Use starquad cable for best noise rejection, and if not using phantom power but powering the mic from a separate supply at the far end, at least one transformer to avoid earth problems. Sorted.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 19th August 2012, 09:55 AM   #24
Originally Posted by jcx View Post
no mention yet of phantom powered mics?
post7
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 19th August 2012, 11:52 AM   #25
QUOTE=AuroraB;3132097]Meaning there is or isn't power.....?[/QUOTE]
I meant that it is possible to get power locally at the main gate. I will use a stablised supply of 12volts DC for the condenser mic.
Will also use another stablised +-15volts DC for the preamp at the sending end. All of this together with the balanced preamp in one enclosure within an outer enclosure conforming to IP65. Owing to its low output impedance, I reckoned using a pair of the Elektor preamp I have cited in post #1 as a good choice. (Schematic is attached herewith.)elektor_ulti-preamp.gif Run the signal balanced in a standard mic cable.
Receive it at the other end with a Balanced receiver with good CMRR like the circuit in the second attachment.
Sam
how to make pcm1704x4 to output balanced signal? shadownee Digital Line Level 7 1st May 2012 12:30 AM
Way to get a balanced signal out of a PC? ribolovec2 PC Based 3 6th January 2012 03:54 PM
balanced signal gupsta Multi-Way 13 9th May 2008 10:06 PM
Balanced Signal Levels- voltages?? lgreen Parts 5 6th April 2004 03:22 PM
Balanced Signal Through Entire Amp? G-Daddy Solid State 7 11th March 2002 08:46 PM
Copyright 1999-2017 diyAudio
