Balanced Signal over 500 Metres!
Old 17th August 2012, 12:17 PM   #11
Two transformers.
Any chance that what you are describing is balanced impedance connection?
regards Andrew T.
Old 17th August 2012, 12:30 PM   #12
east electronics is offline east electronics  Greece
east electronics's Avatar
in a way yes but the trick is that if you are looking for line level trafos that will be hard to find and expensive
on the other side speaker level transformers exist anywhere cost nothing and do the job with no problems except lower quality due to poor frequency response of the trafos .
kind regards
sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 17th August 2012, 06:30 PM   #13
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
IF you're not expecting "studio" signal quality , line transformers are available for 20-30$ each.... I use quite a number of them for voice++ (10kHz or so) quality distribution.
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 17th August 2012, 07:00 PM   #14
5W speaker level transformer audio grade will not cost more than 2-3 euros or usd in any electronics shop and yes it will not be studio quality ...just almost hifi expect a bandwidth from 100-120 HZ to almost 8.5K ....more than enough for such an intercom application
Old 18th August 2012, 10:53 AM   #15
Samuel Jayaraj is offline Samuel Jayaraj  India
Thanks everyone for your responses. Absolute studio quality is not necessary.
A brief description of the application is as follows: The charitable organization is spread over a large area. The main gate is unmanned and the security personnel are stationed at the next gate which is a little more than 1/2 km away. The two points are connected by a winding road, so they are not in a straight, direct line of sight. They want to have a microphone pick up all ambient sound, synchronize this with their CCTV and make sense of what is going on in the vicinity of the main gate. The gates are shut at night and remain open during the day.
In such a situation, covering a wide band will convey more information; hence, restricting it to speech bandwidth may not be the best situation.
HDP pipe has been laid but no cable has been run as yet for this purpose.
Thanks again, for any further inputs.
Sam
Old 18th August 2012, 11:37 AM   #16
tvrgeek is offline tvrgeek  United States
If you have power at the gate, then I too would be thinking RF. Running 600M of cable is not cheap, and prone to damage. ( big expense if pipe was laid before working out these details.) Could you modulate the audio and piggy-back on the CCTV cable?
Old 18th August 2012, 11:54 AM   #17
demeterart is offline demeterart  Greece
demeterart's Avatar
this is crazy. you can even pick up power line hum (magnetically induced50/60 Hz) with such lengths. my advice is to place an amplifier right at the microphone site, remotely power fed with a three wire cable and have at least one more repeater.
Old 18th August 2012, 09:11 PM   #18
demeterart's Avatar
better yet. use a two wire twisted pair and treat it like a telephone system. send dc power over the wires for remote amplifier and superimpose the audio with a balanced system just like in telephony. since it works for several kilometres in telephony it will definitely work in your case.
Old 18th August 2012, 10:06 PM   #19
jcx is offline jcx  United States
Default is this really a Audio Forum?
no mention yet of phantom powered mics?
shielded twisted pair XLR cables, 48 Vdc power appled between the pair and the shield is a pro standard
active buffered phantom powered mics can have <100 Ohm output Z, will drive 1000 m of <100 pF/m cable with ~ 16 kHz -3 dB point
Old 18th August 2012, 10:06 PM   #20
DUG is offline DUG  Canada
The 50 ohm feed and coaxial cable is the right idea as suggested by Jan Dupont.
Cable TV uses DC and RF over the same line...30VDC and lots of TV channels.
If you need phantom power then transformer or inductor isolation of the AF and DC is another option. (see jpg's for ideas)
Make sure the Microphone side power requirements are less than 18 mA due to max 144H unbalanced current limitations.
Transformer-less dc coupled circuits can also be used with 50 ohm coax.
Try to amplify as much as possible at the microphone end.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Balanced Signal over 500 Metres!Hide this!Advertise here!
how to make pcm1704x4 to output balanced signal? shadownee Digital Line Level 7 1st May 2012 01:30 AM
Way to get a balanced signal out of a PC? ribolovec2 PC Based 3 6th January 2012 04:54 PM
balanced signal gupsta Multi-Way 13 9th May 2008 11:06 PM
Balanced Signal Levels- voltages?? lgreen Parts 5 6th April 2004 04:22 PM
Balanced Signal Through Entire Amp? G-Daddy Solid State 7 11th March 2002 09:46 PM
Copyright ©1999-2017 diyAudio
