Balanced Buffer Needed with a Balanced Volume Control? Balanced Buffer Needed with a Balanced Volume Control? - diyAudio
Old 29th July 2012, 04:34 AM   #1
DualTriode is offline DualTriode  United States
Smile Balanced Buffer Needed with a Balanced Volume Control?
Hi All!
I am trying to pick the correct forum to place this post in?
I am a little slow to the party; I just bought a Cambridge Audio DacMagic DAC box. My question is about the balanced line level output of this thing.
First stop is to connect this thing to a balanced “pro audio” SS power amplifier. Will a passive balanced volume control (passive line stage) work or do I need something like a balanced B1 buffer in there too?
Suggestions? Recommendations?
DT
Old 4th September 2012, 06:03 AM   #2
clm811 is offline clm811  United States
clm811's Avatar
Default Balanced B1
Hi.
I also bought a DacMagic with balanced outputs and am building a balanced B1
from imported boards(see pic). You'll need two stereo boards plus a 4-gang pot.
I look forward to using this combo to drive a Forte power amp with balanced inputs.
-Chas
Old 7th September 2012, 12:55 AM   #3
clm811's Avatar
Just finished final assembly,
Everything works, exept for a defective 4-Gang Attenuator (from China on eBay) I am contacting the vendor to see about a replacement, but it's way past the 14day return period...
I wired it up with a one stereo pot on each channel, and the sound with CD's is GLORIOUS!
I've just ordered a 24bit/192kHz USB to SPDIF adapter, so I can listen to my PC.
-Chas
Old 7th September 2012, 09:21 AM   #4
fit a bal to unbal input transformer to your amplifier.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 8th September 2012, 07:16 PM   #5
Hello clm811,
Nice project, your Balanced B1 Buffer.
Did you try the passive approach, without the B1 buffers, with only the ganged attenuators between the DacMagic output and the power amplifier input?
DT
Old 9th September 2012, 04:37 AM   #6
clm811's Avatar
Thanks for the kind words.
Nope, I was concerned about input/output impedance, so I went with the buffered approach.
The sound is quite nice and I don't find myself wanting to turn down the volume as much as before(lower distortion?)...
-Chas
Balanced Buffer Needed with a Balanced Volume Control?Hide this!Advertise here!
Balanced volume control question andyjevans Tubes / Valves 1 5th December 2005 04:12 AM
balanced volume control skaara Pass Labs 99 27th May 2004 03:46 PM
Balanced volume control? MWP Chip Amps 2 1st November 2003 05:36 AM
Aleph P 1.0 balanced volume control Grip Pass Labs 6 2nd October 2002 12:10 PM
balanced volume control diy student Solid State 2 16th January 2002 12:23 AM
Copyright ©1999-2017 diyAudio
