$150-200$ Preamp Build? - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 26th July 2012, 11:24 PM   #1
Default $150-200$ Preamp Build?
Hi guys, i want to build an preamp for my PC, i already build some amps, but my new sound card have an analog optput that need to be used with an preamp.
What recommend me? mainly i want to attenuate the level output. dont want to spend more than 200USD. If is possible to build osmething cheap with good specs will be great!
Old 27th July 2012, 12:03 AM   #2
adason is offline adason  United States
adason's Avatar
so you want to amplify or attenuate...what is it?
Old 27th July 2012, 05:07 AM   #3
Thanks, my english is not good
Mainly i want to control the output (loudness), i cant control it trough the PC, because the analog output of the sound card cant be controlled trough the PC.
Old 27th July 2012, 05:25 AM   #4
was thinking about "stepped attenuator" thats why i type "attenuate"
Old 27th July 2012, 11:19 AM   #5
DF96 is online now DF96  England
Volume pot in a box, otherwise known as a 'passive preamp'. Unless your PC has a very high quality sound card, not worth spending more than $20 on it.
Old 27th July 2012, 12:34 PM   #6
KaffiMann's Avatar
Considering I'd prefer not to use normal pc soundcards above 0,4-0,6V output, suprisingly many tend to distort, even some of the supposed good ones. I think it is very reasonable to have some sort of buffer with volume on the analog out.
I have not tried any of these products, but from ska-audio you can get: SKpre + DualSKpreReg and a transformer and you're good to go, price seems very reasonable. Alternatively you can go for the cheaper Vbuffer solution.
Another very valid alternative would be a proper usb dac of some sort.
Edit:
What is the name of your sound card?
Been using Vivaldi browser for a while now. www.vivaldi.com
Really does feel like the spiritual successor to Opera 12, very good.
Old 27th July 2012, 02:35 PM   #7
hi guys, the Sound Card are high quality one. I want to purchase/build some good one.
The sound card is an Onkyo SE-200.
•Signal-noise ratio: 115dB (2ch ANALOG OUT)
•Frequency characteristic: 0.3Hz~88kHz( 2ch ANALOG OUT , +0/-3dB )
•Line output level: 2.0V rms
•Digital IN sampling frequency: 32, 44.1 and 48, 88.2, 96kHz
•Digital OUT sampling frequency :32, 44.1 and 48, 88.2, 96kHz, 176.4, 192kHz
For sale: Visaton B 200 pair (2x) excellent condition, original box $150 + shipping agent.5 Swap Meet 2 8th July 2012 08:43 PM
Current-feedback amp, 150 a 200 watt. kees52 Solid State 12 26th November 2009 05:53 PM
WTB in Oz: 150-200 watt stereo power amp otto88 Swap Meet 4 20th December 2007 06:06 AM
amp 150-200 W 8ohmi Drago5 Solid State 3 2nd May 2006 04:53 PM
If you had $150 -$200 to spend what Midrange/midbass would you buy? jainbaby Multi-Way 7 18th September 2003 08:41 AM
Copyright 1999-2017 diyAudio
