lpf and hpf setting.
Old 25th July 2012, 11:08 AM   #21
olsound is offline olsound
Does it matter which one of these filters(butterworth,bessel are linkwitz-riley) i use at the begining and at the end of each frequency range.
Countryman skank
Old 25th July 2012, 12:11 PM   #22
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
The type of the filter make the difference in the passband characteristic, and the way that the rejection band is entered, this means the slope of the output/input as function of frequency it responds.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 25th July 2012, 12:40 PM   #23
I read what you wrote but I don't understand one thing you said.how I am confuse again. Lol.
Which filter is best to use for certain frequency range.
Eg is butterworth filter better to use for bass or highmid.
Countryman skank
Old 25th July 2012, 12:43 PM   #24
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
In simple words a filter has two main parameters: the type and the slope.
The slope says how steep it rises or falls at the xover frequency. It depends a lot on the driver in your speaker. If you have a driver that is flat to say 10kHz and you want to roll it of at 3kHz you'd probably want to use a 2nd or 3rd order filter (higher order = more steep).
If your driver falls of at 3kHz from itself, you can use that to ease the slope of the filter.
The type of filter says, roughly, something about how flat it is in the passband, and whether there is any over- or undershoot at the xover frequency.
But thats another story.
jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 25th July 2012, 12:54 PM   #25
Each kind of filter works pretty fine in all frequencies, at the condition it is well designed, properly made (physically) and right loaded at both ends. The difference is the slope and the ripple inside the passband. Tchevishev has high slope but lot of ripple inside the passband, Butterworth has low ripple at the cost of not so sharply defined in and out of band limit (less slope of the Vo/Vi in function of frequencies).
Old 25th July 2012, 02:31 PM   #26
jan.didden's Avatar
Osvaldo,
Did you follow the posts of the OP? Do you think your posts are helping him?
We already know you are very smart, so not necessary to advertise that again
jan didden
Old 25th July 2012, 04:13 PM   #27
Originally Posted by janneman View Post
Osvaldo,
jan didden
Im trying, really I don't know. Why not to wait that the guy started the thread judge it??
lpf and hpf setting.Hide this!Advertise here!
LPF HPF in HU? typo Car Audio 0 15th March 2011 08:04 PM
Setting Amp HPF and Adjusting Cabinet Size bobhula Subwoofers 0 9th September 2009 12:53 AM
split hpf issues? jethdub Chip Amps 0 6th June 2008 01:22 AM
CAP for HPF ? foo Multi-Way 0 27th March 2005 04:25 PM
what are peoples views on using different frequency HPF and LPF to make a crossover? Puggie Multi-Way 13 13th October 2004 10:07 PM
