lpf and hpf setting.
Old 24th July 2012, 11:28 AM   #11
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by DF96 View Post
As Jan told you, .
xedited. It's not the freq range he's after, but the actual working of a hpf and lpf, I guess.
jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 24th July 2012, 11:39 AM   #12
DF96 is offline DF96  England
No, I think he has a subwoofer etc. and he wants to know how to choose the crossover frequencies. The full answer has to be "go away and read books on filter theory and electroacoustics, then find out/measure the bare response of your speakers in your room, then choose crossover freqs which gives flattest/most impressive response for the type of music you listen to" but that won't help him very much.
Old 24th July 2012, 12:25 PM   #13
jan.didden's Avatar
Googling lpf and hpf would have given him what he wanted....
Wikipedia is your friend.
Old 24th July 2012, 01:29 PM   #14
olsound is offline olsound
jan
You are correct. This is what I am after, so some helpful information would help me understand more about hpf and lpf.
Countryman skank
Old 24th July 2012, 02:05 PM   #15
=janneman;
Edit: you mean that you need to know how a hpf or a lpf works? It's all in the name.
If your midrange can handle say 100Hz to 3kHz, you set a hpf at 100Hz, that wil 'pass' all signals above (higher than) 100Hz to the midrange.
You then set a lpf at 3kHz which will 'pass' anything below 3kHz to the midrange but progressively cut of signal above 3kHz. Does that answer it?
jan
Yes you are correct.
Here is more frequency setup.Bass 35hz to 90hz , midbass 80hz to 250hz, midhighs 200hz to 1.5 khz and highs 1.5khz to 20000khz.
I just need some help on how to apply the hpf and lpf to the difference frequencies.
Thanks.
Countryman skank
Old 24th July 2012, 03:21 PM   #16
Now I don't understand what you are asking. If you want to know how a filter works, then Google is your friend. You don't seem able to ask a meaningful question with enough supporting information for us to answer it.
One thing which might help is if you set a country flag. Then someone who speaks your native language may be able to help you express your question.
Old 24th July 2012, 04:12 PM   #17
jan.didden's Avatar
Thanks.
Did you understand this:
janneman; Edit: you mean that you need to know how a hpf or a lpf works? It's all in the name.
jan
Old 24th July 2012, 04:49 PM   #18
[QUOTE=janneman;3102667]
Edit:
jan[/QUOTE
Does the same method goes for sub, midbass and highs.
Yes, i think I get it now.
Sorry for the poor english.
Countryman skank
Old 25th July 2012, 06:55 AM   #19
jan.didden's Avatar
[QUOTE=olsound;3102979]
Edit:
jan[/QUOTE
Yes indeed! Just fill in the right frequencies for each range.
It helps to draw a graph for this.
Horizontal axis from 20Hz to 20kHz.
For this purpose you don't really need a detailed vertical axis, just label it 'high' and 'low'.
Mark all xover points on the hor scale and then draw for each range a line 'high' between the xover points, sloping down to 'low' on either side of the range. For a 4 way system you'd get 4 of these mountain-like curves. I always use different pencil colors for each range.
Pick a range and it is clear that going from left to right you first need a hpf and then on the right side a lpf.
If you are not confused enough ;-) : a hpf also can be seen as a low-cut filter, and a lpf a hi-cut filter. The graphs I described before make that abundantly clear.
jan
Old 25th July 2012, 11:05 AM   #20
[QUOTE=janneman;3103725]
jan
Got it. i will post the graph later.
Btw I am alway confused. lol
Countryman skank
lpf and hpf setting.Hide this!Advertise here!
LPF HPF in HU? typo Car Audio 0 15th March 2011 08:04 PM
Setting Amp HPF and Adjusting Cabinet Size bobhula Subwoofers 0 9th September 2009 12:53 AM
split hpf issues? jethdub Chip Amps 0 6th June 2008 01:22 AM
CAP for HPF ? foo Multi-Way 0 27th March 2005 04:25 PM
what are peoples views on using different frequency HPF and LPF to make a crossover? Puggie Multi-Way 13 13th October 2004 10:07 PM
