After search...need schematic to stereo preamp with only 4 bjt transistors
Old 24th July 2012, 07:09 PM   #21
WhiteRhino is offline WhiteRhino  Israel
I did excatctly like this .
I used only 2 transistors , BC550c NPN and BC556 PNP
Old 25th July 2012, 07:58 AM   #22
Mooly's Avatar
So using the values you have we get the following...
Look how the 0.47uf cap limits the low frequency response and how raising it extends the response. An electroylitic is fine here (watch polarity).
Also see how the response of the amplifier falls at high frequecies. With the higher gain the 100pf cap is limiting the bandwidth. Look at the difference between 100pf and 22pf.
Five screenshots showing this,
1) Output Max. Your amp as it stands into 100k
2) Response. Your amp.
3) Response larger value C1 shows extended LF response.
4) 50Khz squarewave. Your amp as it stands.
5) Lower value of C2. Extends the HF response.
Old 25th July 2012, 08:08 AM   #23
thanks mooly , i will do that ,
I will put 4.7uf instead of 0.47
and 22P instead of 100p
Old 25th July 2012, 09:09 AM   #24
R.I.P.
Hi, have look at Minimalist Discrete Hi-Fi Preamp , note the supply, rgds, sreten.
Old 25th July 2012, 11:11 AM   #25
Thanks look very interesting maybe I will build it some day
For now I will stay with the radford design
Have a nice day
After search...need schematic to stereo preamp with only 4 bjt transistorsHide this!Advertise here!
Active Stereo Preamp , OPAMP VS TRANSISTORS , which on would you prefer ? WhiteRhino Analog Line Level 6 11th May 2012 07:05 PM
search for NAD C160 Preamp service manual or schematic cocolino Solid State 9 28th February 2012 11:40 AM
European Transistors Equivalent Search Algar_emi Solid State 7 27th September 2010 12:07 PM
Schematic Search - Eden VT-.40 (Valvetech with Demeter Preamp) duff2 Solid State 3 27th August 2008 09:00 AM
In search of power supply schematic for phono preamp jduffy Tubes / Valves 16 9th April 2007 04:58 PM
