Go Back   Home > Forums > Source & Line > Analog Line Level
Old 25th July 2012, 10:44 AM   #31
EUVL is offline EUVL  Europe
I thought you already built P2P ?
Patrick
xen-audio.com
Old 25th July 2012, 11:12 AM   #32
Joachim Gerhard's Avatar
No, but i used the same principle in a phono stage. It works, that what i know.
I am waiting for the MosFets.
Old 25th July 2012, 11:19 AM   #33
The mosfets just came. Now i have everything to build it.
Old 25th July 2012, 11:26 AM   #34
This is approximately the input stage of the bespoke phono.
The problem is not new to me and this is a topology that can be used more universal.
So when the request came up to make a simple Bal-Umbal converter i already had a solution. I used current mirrors though.
Old 25th July 2012, 11:39 AM   #35
I know you like current mirrors.
I like the simplicity of cascodes.
Matter of taste.
Patrick
xen-audio.com
Old 25th July 2012, 11:51 AM   #36
I do mostly mirrors. MiiB, Sigurd and i have researched them now to a point where they virtually introduce no distortion. It is more complex then a cascode Widlar or Wilson though.
I use folded cascodes too but instead of the drain resistors i use constant current sources.
They have their problems too like noise but that can also be solved. One of the reasons i went so far with mirrors is that the folded cascode is very well researched and we have
very good and mature examples like the Blowtorch. I simply wanted to try something new. Driven cascodes are also very interesting and i found new ways to implement them. Lets see what will happen in the future. Electronics design is certainly still moving
forward.
Old 30th July 2012, 11:00 AM   #37
Joachim,
Schematics and Infopak already sent to you by email, as requested.
Patrick
xen-audio.com
Old 30th July 2012, 04:09 PM   #38
Thanks, i have now all that i need.
Old 31st July 2012, 08:44 AM   #39
Not quite.
PCBs on their way.
Patrick
xen-audio.com
Old 31st July 2012, 12:01 PM   #40
That looks very good ! I am looking forward to make it play.
Single Ended to balanced for F4 Joshua_G Pass Labs 10 24th April 2011 10:57 PM
How to add balanced input to single ended amp? jaistanley Class D 5 2nd December 2010 04:29 AM
Single-ended input to balanced output, no DC offset LineSource Solid State 16 19th October 2005 09:32 PM
Converting single ended amp to balanced boyelroy Solid State 15 10th November 2002 04:51 PM
Does it Make Sense? Balanced to Single Ended Super_BQ Pass Labs 3 3rd October 2002 09:01 AM
Copyright ©1999-2013 diyAudio
