The XCEN -- Balanced to Single Ended Converter - Page 12 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 24th February 2013, 09:33 PM   #111
NicMac is offline NicMac  Italy
NicMac's Avatar
Originally Posted by EUVL View Post
Here a few pictures of the latest CCS version.
In: "going all the way", nobody beats you Patrick!
Old 24th February 2013, 10:37 PM   #112
tvrgeek is offline tvrgeek  United States
Maybe more grasping at straws for something in topology that relates to perceived sound quality. I had not heard a reason I am off the cliff on this. Good point, parastatics may swamp it. That's as good a reason as any. Might that suggest the ubiquitous BJT/LED is good enough for most standard applications.
Old 25th February 2013, 03:42 AM   #113
EUVL is offline EUVL  Europe
Joachim,
Your heat spreaders and special heat sinks will be on their way this week.
Will email you for details in the next few days.
But all to no vale, since it seems I still need the servo in the end.
Patrick
xen-audio.com
Old 25th February 2013, 04:11 AM   #114
Joachim Gerhard's Avatar
Thanks, and yes, why not a servo ?
Old 25th February 2013, 05:05 AM   #115
Added complication, and some people swear they affect the sound .....
So I took the challenge to try to do without.
But as you also said before, doing it for circuits without global feedback is very tricky ....
Apparently the N and the P devices do not track each other very well thermally.
Patrick
xen-audio.com
Old 8th May 2013, 11:59 AM   #116
Nikitas is offline Nikitas  United Kingdom
Nikitas's Avatar
any updates?
Old 8th May 2013, 12:43 PM   #117
If you follow other threads I post, you would notice that I have a HAGS module (gain of 4) for the DAO SE headphone amp.
The DAO SE all-FET Class-A ZGF Headphone Amplifier
This has been proven to be DC stable even with gain of 4.
The circuit topology is very similar to that of the XCEN, so that I can see no reason why it cannot be adapted.
So at this moment, we'll finish th ework on the HAGS first before we come back to adapt the results there for the XCEN.
Patrick
xen-audio.com
Old 18th March 2014, 11:56 PM   #118
maxpou is offline maxpou  Canada
maxpou's Avatar
Hi Patrick,
do you worked on this projet?
Maxpou
Single Ended to balanced for F4 Joshua_G Pass Labs 10 24th April 2011 10:57 PM
How to add balanced input to single ended amp? jaistanley Class D 5 2nd December 2010 04:29 AM
Single-ended input to balanced output, no DC offset LineSource Solid State 16 19th October 2005 09:32 PM
Converting single ended amp to balanced boyelroy Solid State 15 10th November 2002 04:51 PM
Does it Make Sense? Balanced to Single Ended Super_BQ Pass Labs 3 3rd October 2002 09:01 AM
Copyright ©1999-2017 diyAudio
