The XCEN -- Balanced to Single Ended Converter
Old 21st July 2012, 07:23 PM   #11
EUVL is offline EUVL  Europe
Can you post a link to a datasheet ?
Patrick
xen-audio.com
Old 21st July 2012, 08:03 PM   #12
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
One improvement could be a CFP at the input instead of the lone Fets. That lowers Gm variations.
Old 21st July 2012, 08:37 PM   #13
bcarso is offline bcarso  United States
diyAudio Member RIP
2N4391 -92, -93 and their plastic equivalents PN4391 etc., J111, 112, 113 I believe, also SM MMBF4391. See for example http://www.fairchildsemi.com/ds/MM/MMBF4391.pdf.
I like the 2N part because it can be used a fairly high dissipations when in a heatsink, some of which have a threaded stud and an insulating disc (the gate is common to the case). A few people still make them and someone found some in surplus recently.
Here's some data with typical curves: http://www.fairchildsemi.com/ds/J1/J112.pdf
Old 21st July 2012, 08:45 PM   #14
There still is the problem with P-channels.
Old 21st July 2012, 08:48 PM   #15
Funny enough here is a single ended Bal-Unbal converter. That also has the CFP i am talking about, just made parallel symmetric as we do here.
Old 21st July 2012, 09:39 PM   #16
Nikon1975 is offline Nikon1975  Austria
Interesting ! Hope I will have time to catch on with all the projects when my shipment will arrive.
Good job.
Davide
Old 21st July 2012, 09:41 PM   #17
Was time to change flag :-)
D.
Old 22nd July 2012, 05:33 AM   #18
Calvin is offline Calvin  Germany
Calvin's Avatar
the 4391 makes a nice cascode to BF862 and SK170/389 in a ccs-loaded sourcefollower buffer with considerably better performance than a simple ccs-loaded follower alone.
jauu
Calvin
Old 22nd July 2012, 06:42 AM   #19
We had something like that here, but used J111 or J310 as cascode.
The reason that I prefer J111 is that there is a P-counterpart, namely J174.
http://www.diyaudio.com/forums/digit...ml#post2867664
http://www.diyaudio.com/forums/attac...c.tsc-tina.pdf
But I would be interested in a 2Nxxxx part as an alternative to 2SK246/2SJ103.
Any suggestions for a good, truly complementary pair ?
Patrick
xen-audio.com
Old 22nd July 2012, 07:50 AM   #20
> Of course if you make it symmetric after the input Jfets it will also convert
single-ended to balanced.
Nelson, how about this one ?
http://www.diyaudio.com/forums/attac...-paraphase.jpg
Patrick
xen-audio.com
The XCEN -- Balanced to Single Ended ConverterHide this!Advertise here!
Single Ended to balanced for F4 Joshua_G Pass Labs 10 24th April 2011 10:57 PM
How to add balanced input to single ended amp? jaistanley Class D 5 2nd December 2010 04:29 AM
Single-ended input to balanced output, no DC offset LineSource Solid State 16 19th October 2005 09:32 PM
Converting single ended amp to balanced boyelroy Solid State 15 10th November 2002 04:51 PM
Does it Make Sense? Balanced to Single Ended Super_BQ Pass Labs 3 3rd October 2002 09:01 AM
Copyright ©1999-2017 diyAudio
