| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Have any body Sub woofer controller circuit diagram ? please send me. I have already visit ESP project.
#2 |
i guess you meen active sub filter. here is a finiched board.
Sub Active Filter Board, SubWoofer PCB, Auto Power ON | eBay
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
#3 |
Cute little board on e-bay. But,
You want a sub controller, so you know you are looking for more than just a crossover. There are several approaches. One is the LT kind of circuit if you are doing a sealed sub. (On ESP) Another is more of a parametric filter. (also on ESP) Years ago there was one product that was a 5 band eq for 250 Hz and below with a crossover. Nifty. You could adjust the frequencies and Q of any equalizer circuit to do this. Again, I think ESP has a project like that. Another approach is to use a DXC or MiniDSP. Far more flexible. I recommend you visit the Linkwitz site and read what he has to say about sub controllers. My experience, the variable phase is useless. I move my subs around and do better by making use of the room. Evaluate your needs carefully. Right now, none of my three systems with subs use any eq. The rooms combine with my speaker designs to be just about right. Only one of the systems has an external crossover. Again, by designing as a system, the two smaller systems with plate amps use the internal crossover. Only my main system where I run two subs off a Parasound amp has a complete 4th order two way LR crossover. A modified Behringer actually. One of these days I should build a nice FET high pass instead. Anyone got a good handy design? |
#4 |
#5 |
Nice. Combination of a parametric filter and a crossover. I very much like the 4th order on the woofer so you don't localize it. Second at 80 Hz ( THX) I can. The two systems where I use a plate, the subs are very close to the mains, so 60 Hz second works OK. The above mentioned design would still need an additional crossover for the mains.
I did run across a FET crossover design on Enjoy the Music. |
#6 |
Reckhorn is another option.
#7 |
I would seal the mains and use a LT-cirquit creating an acoustical HP function = 12 dB/oct @ 80 Hz Q=0,707 in series with a conventional 12 dB/oct @ 80 Hz Q=0,707 HP-filter to create a perfect 4:th order LR HP-function.
You could also use just a plain 12 dB/oct HP-filter leg like in most surround receivers, but then I would use a 30 dB/oct LP-filter with adjustable Q to make provisions for optimal integration. I also like steep LP-filters. They really make a difference. |
#8 |
the subfilter i linked to has the same adjustments as the LCaudio circut.
| WTB: 6.5" woofer to replace broken woofer in cheap band pass subwoofer | Jimmy154 | Swap Meet | 2 | 5th October 2010 02:00 PM |
| Woofer replacement for Infinity Reference 2000.5 Woofer | kchilaka | Multi-Way | 0 | 28th September 2010 05:11 AM |
| Samsung 1602VFD For CDROM Controller & Remote Volume Controller | slowgay | Swap Meet | 2 | 22nd November 2008 02:44 PM |
| Active Sub-Woofer and Controller frequency adjustment | PetarLD | Solid State | 3 | 19th June 2005 04:50 PM |
| Qts of Push-pull woofer and Compound Woofer System... | haggy | Multi-Way | 1 | 13th December 2001 01:30 AM |
