Mixing slope types? - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th July 2012, 08:58 PM   #1
nonsuchpro's Avatar
Thumbs up Mixing slope types?
Hey all,
What are the advantages/disadvantages of mixing slope types? I can do this on my Ashly electronic crossover but really am wondering if it is done with passive crossovers much. For instance... use a Linkwitz-Riely slope on the woofer and then a Butterworth on the tweeter
1800hz
Linkwitz-Riely
C2 = 5.53 uF
L2 = 1.41 mH
1800hz
Butterworth
C1 = 7.81 uF
L1 = 1 mH
Thanks in advance!
My Studio
Old 15th July 2012, 01:45 AM   #2
Speedskater's Avatar
Often a driver has an acoustic roll-off near the cross-over frequency. That roll-off counts as part of the slope.
Kevin
Old 15th July 2012, 01:59 AM   #3
5th element's Avatar
Well as speedskater says the drivers own frequency response contributes significantly to the final acoustic result.
When discussing xover types one usually is talking about the acoustic response, that is the drivers own natural response + what the electrical filter adds to it.
In terms of loudspeaker design what the electrical filters are doing is rather academic, it is the final acoustic result that we are interested in. Say for example a 4th order Linkwitz Riley (Q = 0.5) target at 2Khz, this might actually require a second order electrical filter with a Q of 0.3 at 2.2kHz. The filter isn't interesting, the result is what is.
Now of course the filter is interesting if it doing something that you'd rather it shouldn't, like lowering the input impedance too low, or, in the case of active filters, creating areas of very high gain that could cause your amplifiers to clip and your drivers to explode.
Now with regards to combining different acoustic targets, this happens a lot where you will see a designer using asymmetrical slopes. This is generally done to ensure that the drivers of a system sum correctly with respect to their phase alignment.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 22nd July 2012, 04:16 PM   #4
tvrgeek is offline tvrgeek  United States
What 5th said. As usual.
Mixing Resistor types? Bloodcore Parts 4 28th June 2011 11:43 AM
mixing coupling cap types PRNDL Tubes / Valves 1 24th December 2007 03:48 AM
Mixing two types of sub boxes? Bogie Subwoofers 0 24th April 2006 03:33 AM
Crossover slope? Mantronic Multi-Way 0 30th July 2003 02:47 PM
Copyright 1999-2017 diyAudio
