Help with preamp build
Old 26th June 2012, 05:03 AM   #1
nonsuchpro is offline nonsuchpro  United States
nonsuchpro's Avatar
Question Help with preamp build
Hey all.
I've built a Velleman preamp but am having problems with it working. Besides soldering mic cables and crossovers, I haven't had any experience with building kits. Here are some pics of what I've done. I will gladly send it to someone to fix for me (will pay, of course) unless you can tell me something to try, I just don't know. I would love to have this work.
Preamp Project pictures by nonsuchpro - Photobucket
Thanks in advance!
My Studio
Old 26th June 2012, 06:20 AM   #2
godfrey is offline godfrey  South Africa
What's wrong with it? What does it do (or not do)?
Old 26th June 2012, 09:17 AM   #3
DF96 is offline DF96  England
You have a meter, and some knowledge of how to use it?
Old 26th June 2012, 09:30 AM   #4
nonsuchpro's Avatar
It doesn't pass signal. If i turn up the volume, it does make a slight buzz. Not sure if this is the issue but it only has 2 pins for IN and 2 or OUT. Since I'm using XLRs, I assumed I would do hot where it say "signal" and pair the black and ground on "ground". The trim pot is working, just no audio. Mic works direct into amp, but not through my box.
My Studio
Old 26th June 2012, 09:31 AM   #5
nonsuchpro's Avatar
I have a multimeter and have some knowledge on how to use it. I know how to test voltage, ohms and amps.
My Studio
Old 26th June 2012, 12:53 PM   #6
Hmmm.....
  • Maybe the input's not connected correctly.
  • What kind of microphone is it? Does it need phantom power?
  • What kind of wall-wart power supply is that? I hope it's DC and connected the right way around. (Don't try reversing it if you're not sure).
  • Sorry, but this is a lousy circuit for a mic preamp anyway.
[OT]
Seems like there's a gap in the market for decent kits. A few weeks ago someone else had problems with another, even worse kit in this thread.
[/OT]
Old 26th June 2012, 01:09 PM   #7
Check DC conditions e.g. opamp output pins 1 and 7. It should be about half the supply voltage. Unplug the input, and put your finger on the input pin. Do you get a loud hum?
Old 27th June 2012, 03:50 AM   #8
nonsuchpro's Avatar
Hmmm.....
[OT]
[/OT]
I double checked the input. Maybe I should try with something other than a mic. I know this is a bs circuit. I just want it working
My Studio
Old 27th June 2012, 03:51 AM   #9
nonsuchpro's Avatar
Will try this, ty!
My Studio
Help with preamp buildHide this!Advertise here!
Preamp Build robywan Analog Line Level 0 21st August 2010 01:17 PM
What preamp should I build? OzMikeH Tubes / Valves 154 21st January 2009 11:07 AM
Build Preamp Jpoole908 Solid State 1 8th June 2008 12:47 AM
Looking for a preamp to build! Dougie085 Digital Source 7 2nd April 2008 08:05 PM
Which preamp to build skaara Pass Labs 4 13th August 2002 09:54 AM
