| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#11 |
IP=intellectual property, but I found it under the link, my mistake.
I took another look at the schematic, and I think it will be unnecessarily noisy. Under this link you will find everything you need to know to do it in a better way: Active Filters The basic problem in the setup you posted is that in the input stage Vin is reduced, and subsequently re-amplified again in the filter stages. About this input buffer: most audio opamps are unity stable, that is, they will not oscillate if gain=1. I have never used an opamp to give a gain lower than 1, because I always thought this could lead to stability issues. Dunno for sure, but better to prevent it.
Second law is your friend. |
#12 |
The non-inverted input is PIN1 & PIN2, if not balanced (unbal). PIN1 is the audio ground in this unbal case.
If balanced then the extra PIN3 becomes the inverted input. Thus PIN2 = Hot = non-inverted and PIN3 = Cold = inverted. This time PIN1 is chassis, not audio ground. |
#13 | |
#14 |
That is what I have. The problem is my inability to alter the drawing! It seems I will have to draw my own symbol, but don't yet know how to. The xover DOES work, it's my ability to post that doesn't.
#15 |
Ok, this is the speaker, and I want to cut the shallow peak at 2kHz. If I have a circuit for that, with variable cut, then I should be able to recalculate for different frequencies. But I need help with the original design.
![]() I plan to put the xover point at 4kHz with 24dB slope, so the 6kHz peak will be tamed to some extent. Anyway, that is on-axis, and I will toe them in to suit. |
#16 |
Hi Awkard,
I would go quite a bit lower than 4Khz for xover, more like 2-ish, depending on the tweeter you are using. What is the manufacturers recommendation?
#17 |
Are you suggesting that because of the 6kHz peak? I can alter the xover point any time I like, but a notch filter would let me play around. Any way, I may change the midrange driver for a different wide range unit. Maybe the L. Cao 8".
At the moment the HF driver is the Jordan JXR6HD, but I also have a Shackman electrostatic panel to try. So I want to make the xover more versatile before I go 3 way. |
#18 |
Yes, I prefer to stay away 2 octaves from a break up peak like that, so that would give you even less. Anyways, slipped my mind you are designing a 3 way, so that means there should be no problem. You would cross over the bass driver not any higher than 500 Hz to the mid anyways, and than mid to high somewhere between 2 and 3 Khz.
#19 | |
I still need the help with a (preferably) single opamp notch filter design. I have NE5534s, OPA132s, OPA604s, AD825s and OPA627s. In the xover itself, I prefer the sound of the AD825s, so would like to stay with them if possible. As for the Jordan JX125s, the 6kHz peak is on axis, the same as the JX92s, so toeing in sharply minimises that. Anyway, the 24dB/octave slope will also reduce it effect on the sound. I appreciate your good advice, but that is something to consider another time. I want to keep the xover point as high possible at the moment, I may change that at a later date, but not now. Linkwitz's site doesn't really help me, I don't have the skill to make use of it, I am more a hand/eye type of person, so although MAKING the circuit is not a problem, working it out is. I have made valve preamps (Croft, Concordant, Paragon) by measuring and copying, they worked fine. But if they developed faults, I was in trouble, no theoretical knowledge. |
| Behringer DCX2496 I want to try active biamping using it as the active xover. | georgehifi | Digital Line Level | 3 | 15th August 2006 07:46 AM |
| Active xover help! | led_zeppelin | Solid State | 8 | 28th September 2004 02:14 PM |
| Analog active xover | JensRasmussen | Multi-Way | 36 | 3rd May 2004 03:50 PM |
| active xover | 5th element | Solid State | 0 | 9th March 2003 07:19 PM |
| ACTIVE XOVER | KIERANPHILLIPS | Solid State | 4 | 20th August 2001 07:29 PM |
