Modifying Maplin preamp kit
Old 16th June 2012, 09:54 PM   #21
mfurseman is offline mfurseman  England
With the volume pot turned down almost all the way, just enough to hear, and with the power on, the signal does not sound distorted.
I hope that I made it clear that the signal was only distorted with low voltages connected to the opamp supply (1.5V and 3V, also from batteries), and was completely silent with a higher voltage battery (9V), as if the opamp was dragging the signal down.
Old 16th June 2012, 09:57 PM   #22
M Gregg is offline M Gregg  England
Ok,
So you are saying it works..but with 9V or more it shuts down?
At what voltage does it work up to and at what voltage point does it shut down?
I guess you are using pure DC batteries not a wall wart PSU?
M. Gregg
Old 16th June 2012, 10:01 PM   #23
Yup, when unpowered it works, as the voltage is increased it becomes more distorted and quieter until becoming silent.
Old 16th June 2012, 10:04 PM   #24
What happens if,
You remove R2 and R6?
Internal compensation for unity gain?
Is C3/C6 the right way around?
Output short protection cutting in?
M. Gregg
Old 16th June 2012, 10:06 PM   #25
DF96 is offline DF96  England
A wiring error is probably causing the op-amp to stick to one supply rail as soon as it switches on, thus shorting the signal. Check for solder bridges or wrong resistor values. Measure the DC conditions and post the results here.
Old 16th June 2012, 10:11 PM   #26
LOL,
you got to admit its interesting..Hopefully this is already checked..
M. Gregg
Old 16th June 2012, 10:13 PM   #27
I guess,
R7 and R8 are equal values?
I have to sign off now..I'll be back..hopefully someone will pick up with you..
M. Gregg
Old 16th June 2012, 10:19 PM   #28
They are soldered onto the PCB, shorting them seems to make no difference to the way the circuit behaves.
Just triple checked and they are the right way around.
I'm not sure how to check for these, however I don't think the output is shorted, as the volume of the signal is not massively reduced compared to being plugged straight in.
Thanks, Matt
Old 16th June 2012, 10:22 PM   #29
R2 and R6,,
DONT short them remove them...LOL and give it a try..
I'll catch you laters..
The chip has unity gain compensation (internal)
M. Gregg
Old 16th June 2012, 10:30 PM   #30
R7 and R8 each channel,
They should be equal values...
I gotta go ...
M. Gregg
Modifying Maplin preamp kitHide this!Advertise here!
Help! Modifying the Dayton RS1200K kit whbuchan Subwoofers 4 20th November 2010 06:11 AM
X-PRE musical fidelity preamp. need help modifying 04mac Tubes / Valves 10 26th August 2010 09:53 AM
goin 2 visit maplin 4 a pcb kit got any ideas 4 a super newbie Sord_Fish Introductions 23 21st October 2004 08:44 AM
Modifying DoZ Preamp to unity gain PaulHilgeman Solid State 5 28th April 2003 12:28 AM
Modifying preamp power supply Peter Daniel Pass Labs 5 2nd April 2002 09:48 PM
