Go Back   Home > Forums > Source & Line > Analog Line Level
Old 31st May 2012, 09:42 AM   #1
Default Help choosing opamp for this circuit
Hi, I would like upgrade this old preamp amplifier, the actual opamps are NJM4580E smd, I can get NE5532 smd and OPA2134 smd very cheap. Is possible a direct replacement without addind decopling caps or heavy mods? Do you think is worth this upgrade? Forget the filter circuit part, it will be bypassed
Old 31st May 2012, 10:52 AM   #2
this is the circuit
Old 31st May 2012, 02:26 PM   #3
and this is the amp
Old 31st May 2012, 10:06 PM   #4
It's a SONY, eh? Mid-'80s to mid/late-'90s or thereabouts, or that's what I get from the schematic style.
4580Es are in EMP-8 package, which however appears to be almost the same as SOIC-8.
First off, you most probably won't be seeing any dramatic improvements.
That said, let's go through the various stages:
IC801, 807: Balanced input impedances (11k each), no common-mode signal. Output loading can get pretty severe if gain is cranked up. So you need good transfer linearity and good load-driving ability, with mid-low voltage and current noise. OPA2134 is inferior at load driving from about 1 kHz up, so the 5532 it is then. Potential upgrades with yet better performance: LT1469, LT1630.
IC802, 808: An inverting amplifier with potentially low impedances, but receiving noise from preceding stage. Output loading not particularly severe. Pretty much a toss-up, use whichever you like. Alternative: LM4562 (LME49720/49860).
As far as the tone controls are concerned, hmm. Not an expert on these. It seems like the impedances seen by inputs are mid-high and not necessarily matched here, mandating well-controlled input impedance distortion. You could really do a lot worse than with the 5532 here (the 2134 is not even in the ballpark). Some people also like other bipolar parts with moderate input stage current in such applications, like the MC33178 in spite of its rather modest specs (now if that one works well, something like a 4556 also should).
Old 1st June 2012, 06:34 AM   #5
Hallo ! Yes, you are right, Is a old Sony XM 7547 amp (purchased from Germany). I Like the build quality of the old Sony Stuff
Thanks for your clean explication, I'm impressed for your level of knowledge, I will follow your recomendations. The tone controls can be bypassed with a external switch so It will be controlled with the head unit active filters.
I have some small wima's Mks2 4.7uf 50v. and I will replace the input electrolitics caps, maybe is a little upgrade too.
Thaks again for you kind support !
Gruss
Bernat
Old 4th June 2012, 11:14 AM   #6
Not an expert per se, just been poking my nose into Samuel Groner's op-amp measurements and interpreting them.
Incidentally, from this page it would seem that NJM4580 has better current drive capability than NE5532 (or at least that's what I get from the results - unfortunately the test setup used gets multiple distortion mechanisms involved, with output loading often being the deciding factor), so the latter may be performing worse at high gain settings.
Along with the "upgrade" types that I suggested for IC801/807, you could also try a NJM4556 - its noise still is negligible there, and being a headphone driver it's not easily bothered by low-impedance loads. I think that one comes in DMP-8 though, which is a hair bigger than SO-8.
Old 5th June 2012, 09:49 AM   #7
thanks again for your time !
the amp arrived yesterday and after log time of audition I can say I dont't like his sound, is flat and boring, the treble is velled and the soundstage dissapeared. respect to my reference car amp (In this amp changed de opa2604 for opa2134 with very good improvement, I tried too the OPA627AU but was impossible to listen , no bass, no highs just a very distorsioned midrange, probably oscillation problems ).
¿Do you think I will get oscillation problems with the OPAMs you recommend, is already compensated the circuit in the the scheme?
Kind REgards
Bernat
Old 22nd June 2012, 10:56 AM   #8
Well, due the difficults to find the recommended parts I replaced all the opamps with LM4562 just for experiment, I like overall result , the upper midrange seems more relaxed and easy to listen but I think I loosed some bass and dynamics. Maybe I need to replace (or remove) some resistors of the opamp circuit? Thanks
Old 22nd June 2012, 01:11 PM   #9
If you are not prepared to adjust the decoupling, then don't consider swapping the opamp.
Old 22nd June 2012, 03:58 PM   #10
It appears there are two 220 µF electrolytics and two 100 nF ceramics for all the opamps in the input section, with no further local bypass caps. Silly of me not to pay attention. This layout is probably not suited for anything remotely critical WRT decoupling, so it's not a surprise that the OPA627 wasn't amused.
Speaking of the OPA627, I hope an adapter was used for two each?! That would have been the ideal place for some local decoupling caps.
I wish people would just forget about the OPA2604 for run of the mill opamp duties. The strength of this part is operation at higher supply voltages than usual. Only then is it remotely attractive. A bit finicky about decoupling, too.
LM4562s should be reasonably tolerant but still aren't totally uncritical. You can still get them to oscillate.
4556s for IC801/807 should work fine though.
Which opamp in this preamp circuit? lordearl Analog Line Level 5 23rd January 2012 07:14 AM
Choosing an opamp for guitar direct box. Giora Parts 5 18th June 2007 12:38 AM
Can anyone help with this opamp circuit? lt cdr data Solid State 4 20th May 2005 10:12 AM
Transistor/opamp circuit soundNERD Chip Amps 12 15th September 2004 02:16 AM
Help choosing opamp for active filter Alcaid Parts 5 25th February 2004 09:50 PM
Copyright ©1999-2013 diyAudio
