Go Back   Home > Forums > Source & Line > Analog Line Level
Old 29th May 2012, 09:44 AM   #21
tinitus is offline tinitus  Europe
Originally Posted by tinitus View Post
how much do you know about speaker design ?
did I say that ?
I just thought it was ok to ask
but when you are experienced with speaker design, then I dont understand why you focus on precise matching of the electronic side only
its been a while since speaker design have moved beyond that
or do people still think the active design is so superiour that they are 'in the clear'
Old 29th May 2012, 10:05 AM   #22
Originally Posted by AndrewT View Post
Make a list and I will tick off all the bits I do know a little about. I can assure I will not be able to tick off that many but that does not help you in any way.
Andrew, are you saying that you do not know much about speaker design
am I reading you correctly here
Old 29th May 2012, 10:52 AM   #23
I usually make it clear in my posts between guessing and my opinion and facts and regurgitating other's observations.
If you look up Linkwitz you will find just about every EQ and crossover arrangement you could ever require.
Note particularly the difference between crossover and driver EQ.
The driver EQ must be designed and implemented for that driver. Nothing else outside that matters. Move the crossover frequency and the driver EQ stays the same.
Does that sound like I know nothing? If it does then, as I suggested earlier, sort the wheat from the chaff
you asked the question, now you have to decide. Hopefully others will come in to support or not. That makes your job even more difficult.
Old 29th May 2012, 01:55 PM   #24
ah, Linkwitz, yeah, ok
driver EQ ? you mean woofer bass EQ ?
well, thats not even being considered yet
making my job even more difficult ?
yeah, surely, and why not
if I wanted it easy, I wouldnt be here at all
btw, Linkwitz is making fixed custiomised crossovers, by caculations and measurements, and not variable ones, right ?
I could choose to do that, but will focus on a variable filter
besides, the way linkwitz does it looks a bit different from what I see elsewhere
different solutions to the same thing, or ?
but Im not arguing which way is good or better, not at all
and as said, maybe it doesnt get any further than this
if its all about reading Linkwitz, and anything else just guessing, then it surely wont
if you are interested, its good
and if not, thats fine too
its not something I desperately need to do
I just thought it might interest others too
Old 29th May 2012, 02:08 PM   #25
Does that sound like I know nothing? .
if thats all, Im sorry to say yes
its bettert than nothing, but not really much either
Im sure you could tell me how the active filter works, in every detail
and it would all be of very high value to me
but without the understanding of how the speaker functions, it wont really be the info I need
then I could just as well buy a plug and play thing
Old 30th May 2012, 05:50 AM   #26
joexswj is offline joexswj  Indonesia
joexswj's Avatar
I cannot believe fixed xo points work well with any speaker units
well, I do know its 'immune' to the usual issues with varying impedance
which is a real big issue with passive xo
but it still does not deal with frequency changes
with all properly designed passive crossovers, the acoustic slopes have top priority
but obviously not so with active xo
that xo point can be change, and xo schematic should use a buffer
Old 30th May 2012, 06:23 AM   #27
Originally Posted by joexswj View Post
....... and xo schematic should use a buffer
yes, ESP project125, 4way xo, seems more complete
looks like plenty of options to do the xo/EQ combo thing
Project 125
big question is still how, or maybe even why
Old 30th May 2012, 08:55 AM   #28
brig001 is offline brig001  United Kingdom
I'm not sure I am understanding this fully, but I am currently trying to make an two way active crossover where I can vary the crossover frequency and order (and therefore phase) for each way. The best setting I have so far is first order (ish) for the woofer - I think it is already rolling off first order on its own, and second order for the tweeter. This arrangement seems to get better phase between the two drivers than second order on each.
Is this something like you are trying to do?
Brian
Old 30th May 2012, 10:23 AM   #29
Project 125 is a crossover
4-Way Linkwitz-Riley Crossover (LRX424)
It does not have any EQ.
It does not show what may need to be done to correct for driver anomalies.
Old 30th May 2012, 10:31 AM   #30
sure it does
just takes a few minor changes
remember, my goal is a 3way xo
with 24db high pass
and 12db low pass, with EQ
should leave plenty of room and option for that, or what ?
Parametric EQ values? Elbert Analog Line Level 16 19th July 2012 03:53 PM
Open Baffle active Xo/EQ/Amp design Zicdave Multi-Way 0 15th May 2012 09:55 AM
Parametric EQ project ianmgreen Construction Tips 12 2nd April 2011 11:21 PM
LM3886, Leach Amp, Active XO, Subwoofer EQ, Mic Preamp, Joshua Tree, FE103E, More! wigginjs Swap Meet 27 20th September 2008 09:32 AM
Digital active XO+eq using a PC+soundcards+BruteFIR? tcpip Multi-Way 62 27th April 2006 04:34 PM
Copyright ©1999-2013 diyAudio
