| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#21 |
You can search also for the TDA 2320A chip .
Inside the datasheet of the TDA 2040 there's an application circuit that utilizes the 2320A for dividing the signal for woofer and tweeter . very easy , but I don't know the sonic values of the circuit . |
#22 | |
We did a bit of shopping at digikey
![]() ![]() We bought some opa2134, (and some TL072 in sale, just in case). To power them, we bought a pair of ICL7660. They can give us 45mA -12V supply. If this isn't enough current, we will use a 2W DC/DC converter (12Vin, +/-9Vout, for 120mA). We'll make a standard Linkwitz-Riley2 way crossover. so we bought 0.1% tollerance resistors (7.5K and 15K) and 3% 4.7nF capacitors. We have designed an additional output buffer stage with variable gain (using 10K two-ganks potentiometers). Its intended to have a 5V/V gain at full throttle and 2.4 at minimum position. Attached, the simulated circuit. Do you find any error in this? We will then use 2 vu-meter IC at the output, to drive some green+red led (green lights at about 0.7V, red above1.4V) to prevent clipping. Quote:
Or are you talking about decupling DC component in the signal? We haven't planned to add more capacitors for this purpose, we are confident about the input stage of the amp boards, which won't be alterated for now. By now, we have about 2x100W, 2x50W, 2x30W and some smaller solar cells. We have planned a 12V rail for ta2024 (tweeters), crossover and miscellanea, and a bigger 30V rail for the big amp (bi-amped, bi-powered, sounds fine!). We have designed a standard supply regulator for both of them.. Two cells in series give about 40V, we will use some LM338 for 30V regulation and about 0.090F of capacitors for now. After some testing and some math we think that we should need about 1F or 2F for optimal performances at very max volume, in order to cover the current peaks. This would be more costy than buy more solar cells or batteries, and a bit dangerous for outdoor applications. We will use the system in this way for now and, depending of its performance, we will think about more electrolytic, batteries or other solutions if we'll found the necessity. Don't worry, it's quite loud anyway .Btw, we don't want to play at night, there's not many outdoor places where is allowed to play music that loud after the sunset without bad side effects ![]() I tried to post in the boombinator's thread, but no one helped me, they we're saying that I should not talk about different design, 'cause this would be OT. I want to play louder than them, but that seems to not be interesting |
#23 |
Audio Engineer
Hi, Each OPA2314 will require approx 5mA quiescent current per opamp (not per chip). So you can use 4 dual channel opamps chips in your design assuming the load current is negligible (which is likely if the input impedance of the power amplifier is fairly high).
I would think the 8 opamps in 4 chips should be enough to do your L-R filters and buffers. I estimate this should actually take 6 opamps (not dual chips) for a stereo system. Decoupling is for the DC supplies, 220uF should do as bulk decoupling for all the opamps so long as you have 100nF close to each opamp. There is no need for 220uF on each opamp. (If interstage DC block capacitors are used these are called coupling capacitors, as you have indicated its unlikely you will need these) Simulation looks OK. If you use OPA2134 the input offset bias current is so low you don't really need to worry about impedance matching between positive and negative inputs, but it won't hurt if you leave it in. I'll be interested to hear how the amplifier holds up, the peak to mean ratio of music is quite high so even when playing loud the RMS power can be quite low. Worst case music is normally reckoned to have a peak to mean of about a factor of 8. Regards, Andrew |
#24 | |
![]() For each channel (L/R): input->buffer (1opamp)->HF and LF (4opamps)->output buffer(2opamp, one for HF, one for LF) so each channels need 7opamps, that means 7x OPA2314 for the whole board. We now have some ICL7660S, the one with oscillator frequency boost (35KHz instead of 10K). If current is not enough, we can parallel a pair of them or use one for each channel. Btw, they will work at their max rated supply voltage (12V). original 7660 isn't even designed for such voltages. We also have the NMH1209DC that seems really good, and can supply +/-111mA. Maybe an overkill? I'm quite sad 'cos according to datasheet, it seems to need an LC filter for best output ripple, and it's not easy to find a 47uH inductor now...I should have bought it from digikey :@ What design seems the best to you? For decupling...lol, now i've got too many 220uf capacitors . I'll use just one of them (will bigger capacitors work better or just a waste of space on the board?). 100nF will be as close as possible to every IC's Vin pin. they are also quite useful as jumpers, on a single layer pcb ![]() Playing a 0db sine wave at 0.8V rms on a tk2050 channel makes the amplifier put out about 12V on 4ohm. Full power (and 10%THD) can be obtained with a 1.5V rms signal. Under this condition, it gives about 30V rms on the 4ohm speaker, so about 100Wrms, and about 100W of supply power drained (never goes too much over 4A). It's very efficient, as intended! Real music is obviously different. It's never recorded at 0db, standard commercial values are -10 and -6db. Newer music is highly compressed in dynamic, so this helps a bit. The real problem about audio peaks is that they are very long. Relatively to audio signals, they last forever! It's easy to cover voltage ripples, that are high-frequency noise (from eg a switching supply) with relatively small capacitors. But even assuming a reasonable peak/mean ratio, and a not-crap supply bench (like 2X mean power needing) ,in order to cover this "4A, tenth-of-second-long" peaks, we should need huge capacitors . But instead of spend $$$ for more and more farads, a more viable choice would be spending $ on power sources
#25 |
#26 |
Audio Engineer
I haven't used either of the voltage inverters you have listed but the NMH1209DC looks like it will probably give you a better result as it has built in magnetics and is transformer based (providing a better isolation from the main supply) rather than capacitor based.
Bigger capacitors just after the voltage inverter should help by providing a low impedance bulk storage to swamp the output impedance of the inverter. You need to be a bit more carefull with capacitors in the audio circuits as you can just end up coupling noise from the power supplies into the ground return path. Hence it is probably better to just use one set of bulk decoupling capacitors near the opamps. You could use separate bulk caps for the for the H.F and L.F stages depending on how you route them just try not to mix the H.F and L.F ground return paths. Regards, Andrew |
#27 | |
For now, I'm not too worry about supply noises. Power is coming from solar cells and reulated, so there's no much AC components in it. I think it won't be easy to design the pcb with all these requirements. Do you have some similar PCB design that I could look at? Any examples of good designs? Now, it's a shame but i have to ask, 'cos i've not experience about this: The ouptut of each channel's LF will be splitted in two, because a single LF signal will drive 2 tk2050's channels. I've not designed something particular. Actually, the split happens after the output buffer. So what appens after this split? Vrms remain the same, and just the current drained doubles (in this case, will the crossover have some troubles)? Or the split will cause Vrms attenuation, and we'll need more gain to compensate? Or should we make an output buffer for every single output (I hope we shouldn't). Input impedance is about 20Kohm for every tk2050 in, same value fot the little sister's inputs. |
#28 |
Audio Engineer
Hi, for the split the current doubles, opamps are voltage output devices. If the input impedance of power amplifier is 20k then the approx 10k load will be no problem for the opamp in your buffer circuit.
I am not sure if I have any example boards, most of my work has been on commercial designs and normally on 2 layers or more. Single sided layouts are difficult to get working well. I'll have a look and see if I can find anything. Andrew |
#29 |
Audio Engineer
I haven't found any good examples of single sided boards however this guide may be of some help.
http://alternatezone.com/electronics...torialRevA.pdf 1000uF on 9v rails would be a good bulk decoupler after the inverter / regulator. Regards, Andrew |
#30 | ||
Testing Time!
So, we did the schematic for the crossover network and for the dual supply rail, and tested the whole thing on a breadboard (excluding the variable gain output buffer stage). We've not listened at it yet, but we did some measurements. Everything seems just fine! Measurement system is not the best, but seems to do its job: laptop with TrueRTA using a TASCAM US-144 as aq. board. (note: very high frequency response in the LF's plot are reasonably altered by wrong system's self-calibration) I'm quite impressed, it seems to be better than what I expected! We used no particoular decupling, just 100nF near to each opamp's supply rails. No electrolytics are in the circuit. Quote:
| Battery Powered Soundsystem Suit | yashasmasha | Multi-Way | 3 | 17th November 2009 03:39 AM |
| $30 Active Line-Level Crossover | Nappylady | Multi-Way | 23 | 20th September 2005 06:53 PM |
| line-level crossover schematics? (WANTED) | robmonk | Parts | 1 | 13th December 2004 07:31 AM |
| line-level crossover -- design help, please? | robmonk | Multi-Way | 1 | 12th December 2004 09:31 PM |
| Passive line level crossover | rulezzz | Multi-Way | 3 | 7th January 2004 08:45 AM |
