Looking for discrete high performance linestage design with 12v rails
Old 16th May 2012, 09:48 AM   #1
jmillerdoc is offline jmillerdoc  United States
jmillerdoc's Avatar
Default Looking for discrete high performance linestage design with 12v rails
Been searcing the forums to no avail....lookingfor a high performance linestage that will run off 12v +/- rails that is fairly simple to implement. Please let me knowif you habe a good design/schematic.
Thanks!
Old 16th May 2012, 10:15 AM   #2
enregistree is offline enregistree  Europe
enregistree's Avatar
If there is no need for voltage gain, and no SE-BAL conversion needed, then simple is better – volume control at input and high gm JFET buffer loaded at source with matched JFET (DC coupled) to drive power amp input and interconnect cables.
Old 16th May 2012, 03:31 PM   #3
jmillerdoc's Avatar
I have one SE 2A3 tube amp with an input sensitivity of about 4v p-p to clip that would benefit from a slight amount of voltage gain but, this was not my primary purpose for this preamp...i am building a pair of NAP140 clone monoblocks and I wanted a preamp to run them that worked from SLA batteriies (just wanted to try a preamp with SLA power source).
So, not absolutely necessary but if one with a minimal amount of gain were available, that would be beneficial....
Old 16th May 2012, 05:29 PM   #4
The B1 draws an average current equal to the Idss of the jFETs selected. This could be as low as 6mA (for two channels) but more likely to be in the range 12mA to 18mA (for stereo).
regards Andrew T.
Old 16th May 2012, 06:10 PM   #5
jmillerdoc's Avatar
So, will it run on 12v +/- rails?
Old 16th May 2012, 07:04 PM   #6
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
hmm, maybe lazy cat's SSA balanced input/phase splitter with double pair BC550C/560C
I think it runs optimal at +/-15V, and 12V might be fine too, but not sure
Old 18th May 2012, 03:17 AM   #7
RBorkowski is offline RBorkowski  United States
RBorkowski's Avatar
Default Discrete high performance linestage design with 12v rails
jmillerdoc,
Here is a very high performance balanced input linestage designed for a bipolar 12 volt supply. Low distortion - 0.000082% THD. Can be used single ended too, just tie either input to common. Output will remain the same regardless balanced or single ended.
I provided an LTSpice file of it if you are so inclined.
Enjoy...
Best Regards,
Rich
Old 18th May 2012, 04:17 AM   #8
jmillerdoc's Avatar
Awesome...i am not too familiar with this type of schematic. Can you help me with a few small details? The input seems to be on the left side...what is that circle with the +/- inside it? Also, how os the output wired? One side of the "load" resistor is output and the other groind? Can you please explain it a little better for me? I dont know how to convert this into a wiring diagram....
Old 18th May 2012, 04:19 AM   #9
jmillerdoc's Avatar
Also, does this require any close matching of devices?
Old 18th May 2012, 12:41 PM   #10
The post7 sch is bal to unbal.
You can convert it to bal to bal by duplicating Q7&8 and feeding them from the two unused collector resistors R9&11
regards Andrew T.
Looking for discrete high performance linestage design with 12v railsHide this!Advertise here!
High-rails Passlabs amplifier design ? Bønna Pass Labs 19 24th April 2009 01:55 PM
Wanted: 12V Discrete Preamp Design TheSeekerr Solid State 6 11th January 2008 07:20 AM
Does anyone know a bridged design for 12v rails? mpmarino Solid State 3 16th June 2007 12:37 PM
Copyright ©1999-2017 diyAudio
