Go Back   Home > Forums > Source & Line > Analog Line Level
Old 14th May 2012, 12:55 PM   #1
dirkwright's Avatar
Default 2SA1015 SRPP follower bridge mode
So, I'm putting this out there for comments. It's a simple circuit really, with a pair of 2SA1015's in SRPP formation driving an emitter follower on each side of the bridge. Feedback is taken from the emitter follower back to the emitter of the SRPP. I used ideal transformers in the sim because I wanted to know what the circuit was going to do. Obviously, performance will be much worse with real world transformers, which I already have (Jensen). I can't see anything wrong with this circuit so I want to build it but thought I'd post it first just to double check. I hope I didn't make any obvious errors. The only down side so far is that the input impedance is a bit low at 6k ohms.
I've tried different transistors and other arrangements but for 6dB of gain, this is just fine apparently. Performance seems to be really great.
File Type: jpg 2SA1015 SRPP follower bridge Fourier.JPG (39.3 KB, 66 views)
Old 14th May 2012, 01:29 PM   #2
dirkwright's Avatar
I figured out how to fix the input impedance. I changed the bias arrangement to the input transistor by lowering the current through the voltage divider thus increasing the impedance. Overall input impedance is now about 12kohms.
Old 14th May 2012, 02:31 PM   #3
jan.didden's Avatar
Dirk, I was just looking at that.
Another option is to put a resistor between the bias string (top of the diode) to the b of the Q.
Not sure which is more stable - your lean current (which decreases stability of the ref voltage with T) or a series R (which causes some T dependence too).
jan didden
It is a capital mistake to theorise before one has data. Insensibly one begins to twist facts to suit theories, instead of theories to suit facts - Sherlock Holmes Check out Linear Audio Vol 5!
Old 14th May 2012, 02:49 PM   #4
dirkwright's Avatar
jan didden
thanks for the advice! much appreciated!
I lowed the current of the bias divider to a bit less than 500uA and increased the resistor to 5k. The circuit sims almost exactly the same, but of course this may be different in real life.
File Type: jpg 2SA1015 SRPP follower bridge high imp..JPG (96.6 KB, 58 views)
Old 14th May 2012, 03:10 PM   #5
jan.didden's Avatar
I believe the 5k then sets the input Z. The real one will be lower because the dynamic impedance of the diode will be in parallel.
Or is it a current reg diode?
That's probably the best solution - an LM334 (?) current diode, that will work fine with only a few 100uA.
jan
Old 14th May 2012, 03:14 PM   #6
dirkwright's Avatar
jan
They are all current regulating diodes (CRD, CLD, CCD, etc). They are expensive, but they make circuit design more simple for me.
6N16 12x preamp srpp/cathode follower with printed circuit board design. Koifarm Tubes / Valves 51 3rd May 2013 12:16 PM
6N3 SRPP + 6N5P Cathode Follower HPA Testing siliconray Tubes / Valves 9 28th February 2012 08:12 AM
Cathode follower & SRPP q Cobra2 Tubes / Valves 4 22nd February 2008 01:15 PM
Schematic please? SRPP with current source cathode follower riotubes Tubes / Valves 0 7th January 2007 05:18 PM
srpp or m-follower? GAK Tubes / Valves 28 3rd September 2003 06:44 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
