Best OP-amp for EQ circuit?
Old 12th May 2012, 09:02 AM   #1
neskor is offline neskor  Serbia
Default Best OP-amp for EQ circuit?
I'm trying to do upgrade of OP in my JBL 5235 crossover.
OP-amp are NE5532 and TL074.
Any suggestions for best sounding OP-amp in EQ circuit?
Old 12th May 2012, 11:54 PM   #2
Speedskater is offline Speedskater  United States
Speedskater's Avatar
First two questions:
1] Do you have a good oscilloscope?
2] Do you know how to use it?
Kevin
Old 13th May 2012, 01:07 AM   #3
mickeymoose is offline mickeymoose  Canada
First off: Without the schematic no qualified answer can be given (don't ask me (us) searching for it!)
Second: What is it that you would like to improve? Those opamps, even after all these years, have high ratings. E
Old 13th May 2012, 07:17 AM   #4
Here is the schematic.
I don't have oscilloscope
I would like ti improve transparency
Old 13th May 2012, 11:47 AM   #5
Each low pass, high pass, buffer and other use opamp will need to have it's own important parameters identified. Using that information, selected opamps to suit each duty can be inserted and checked for correct operation.
This is not a swap and guess tweak.
regards Andrew T.
Old 13th May 2012, 11:56 AM   #6
Mooly's Avatar
It is important to check for stability when swapping opamps but I think the OPA2134 and OPA4134 would be a safe swap here. It all looks as though it is fairly well compensated already.
Old 13th May 2012, 11:57 AM   #7
jcx is offline jcx  United States
all of the Z are in the range you expect to see fet input op amps - I'd guess that the 5532 was used on the output for its better line driving ability compared to the TL074/2
today there are fet input "audio" op amps with much better outputs - OPA4132/4 and 2132/4 are esy to find in DIP
most recent "audio" op amps are only offered in surface mount - also watch the supply V rating - newer processes often don't handle the +/-18 V supply used on that schematic
Old 13th May 2012, 01:21 PM   #8
Simon B is offline Simon B  United Kingdom
I'm very dubious about there being any value in changing the op-amps without having a clearly identified reason for doing so. Improving "transparency" is a bit of a nebulous starting point for making circuit changes.
Mooly refers to some newer devices as being a "safe swap". They may well work fine in this circuit, but that isn't the same thing as working better.
JCX talks about more modern op-amps with "much better outputs" - from the context I think he means they can source more current, but is it needed?
There's also the small matter of changing them over without making a pig's ear of the pcb. Funnily enough, I'd say the point at which my soldering started to get good was around about the time I got my first scope. And by good I mean able to solder and unsolder devices to a pcb repeatedly without killing it.
I think neskor, that you'd be much better advised to spend time on the things that might well have suffered some degradation over time - switches, pots, contacts of all kinds.
Andrew T has it exactly:
Originally Posted by AndrewT View Post
...This is not a swap and guess tweak.
As does mickeymoose:
Originally Posted by mickeymoose View Post
...What is it that you would like to improve? Those opamps, even after all these years, have high ratings.
Fix the bits that might actually need fixing. Not the ones that almost certainly don't.
Engineer: One who can do for 10 shillings what any fool can do for 10 pounds.
Old 13th May 2012, 02:44 PM   #9
I just took the question as whether there were better speced op amps for that circuit
I agree that there would be little reason to suspect the swap would improve performance audibly
Substituting the OPAx134 would perhaps lower the noise floor by few dB at the input
its a toss up whether the 5532 current noise is worse than the OPA V-noise with those source/feedback Z - unlikely to be heard with any reasonable system gain structure
I have directly observed both the TL07x and NE5532/4 outputs behaving poorly by eyeball on my oscilloscope – the early generation monolithic processes couldn’t make decent PNP
With buffered output the TL07x can provide remarkably low distortion but you really don’t want them driving any load/sinking even a few mA
The 5534 output is better over audio frequencies, distortion with load holding up decently but the sinking/sourcing output dynamic Z is still vastly different at higher frequency, the pull down is way slower than the NPN follower in the output
The shown circuit doesn’t give the conditions that show the output weakness to full effect but the worst case ~ 4 kOhm load for the TL074 would probably be visible in distortion analysis if the unit uses pro signal levels
so replacing the TL074 with OPA4134 would likely result in measurable lower noise, distortion - which admittedly may not be "audible" - maybe less justification for changing the 5532 if sticking with DIP op amps - both choices can be improved on by using smt adapter boards and even more recent chips like the OPA164x
Old 13th May 2012, 03:17 PM   #10
You're quite right jcx, the OP's question was just about op-amps.
I have strayed from that in my answer, though justifiably, I think. I'd certainly want to know what it was I was trying to fix ("imporving transparency" just isn't good enough for me) before setting to swapping active devices. It concerns me perhaps more than it should that folk will think of swapping op-amps before they clean/replace pots and switches.
Best OP-amp for EQ circuit?Hide this!Advertise here!
Summing Op-Amp circuit FastEddy Subwoofers 48 29th November 2015 05:50 PM
Op-amp EQ Experts? Puzzle for you! Zero Cool Solid State 2 16th September 2010 02:45 PM
Unity Gain op amp circuit? jetbat Solid State 3 5th May 2009 01:29 AM
strange op-amp circuit kubeek Parts 23 15th October 2006 07:25 PM
Discrete op amp circuit NickC Solid State 11 19th August 2002 06:50 AM
Copyright ©1999-2017 diyAudio
