Volume Control with symmetrical out and in - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 5th May 2012, 01:40 PM   #1
Default Volume Control with symmetrical out and in
Hello, I was searching for a very good volume Attentor and didn't find something usable and well priced on the market.
My Goal is a "simple" active Volume controll with very high part quality and a negable difference between right and left channel.
A few Day's ago, i found those Volume Attentuator:
High Quality Audio & Industrial Attenuators
Now i started to think about the schematics. The Opamps in the front are not choosen out till now.
My idea was a operational amplifier for a high input inpedance and with some trimmers to get a CMRR>60db. The DC servo is to handle a DC offset of +-100mV (but i need to calculate it again). Do you think it is possible to get a high CMRR with DC Servo in one stage?
The Output stage uses a 1632 to get a symmetrical Signal again. Then Id like to use LME 49990 with the BUF 634 to drive long cables. Mabe it is possible to drive the two BUF directly?
My experience with the buf teached me that the BUF's are not easy to control ner unitiy gain, so i'd like to be on the save.
What do you think about the schematics?
Old 6th May 2012, 12:53 AM   #2
Speedskater's Avatar
I worry about schematics that connect XLR connectors pin # 1 to analog ground.
Kevin
Old 6th May 2012, 08:39 AM   #3
Oh, you are totaly right!
I'll correct this. What do you think about the schematics in general?
Old 7th May 2012, 03:52 PM   #4
There is a "mistake" in my shematics.
The 1632 is builded for an AD converter. It is possible to get a "near symetrical signal" out of a Single ended input.
Depending on my measurements today, it was 20% off
My idea is now to buy a finished Balanced SE konverter and then a SE Balanced Converter from Funk Audio Berlin.
Old 7th May 2012, 07:44 PM   #5
Yes xlr pin #1 to chas. Please have a look at THAT 1642 as bal. outputamp.
//Hans
Old 7th May 2012, 07:58 PM   #6
jan.didden's Avatar
You could put the pot meter directly across the balanced signal insted of one sided to ground.
That way you can lose the bal to se and the se to bal conversion. Saves you most of the opamps
jan didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Remote control Passive Volume Control with Display ua100k Swap Meet 2 31st May 2011 03:01 PM
Replacing broken volume control with digital volume control Gunawan W Solid State 19 15th December 2010 10:46 AM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 03:12 AM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 11:12 AM
Copyright ©1999-2017 diyAudio
